181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. manishtomar116
    Cupcake Mar 6, 2020
  2. DOMINVS
    Donut Mar 6, 2020
    DOMINVS , Mar 6, 2020 :
    When are you going to fix the annoying " Handling Theme" notification that is constantly popping up on my 6T? This has been going on since 10.3 update.
  3. Alex Sem
    Gingerbread Mar 6, 2020
    Alex Sem , Mar 6, 2020 :
    [QUOTE = "DOMINVS, post: 21386533, member: 2575752"] Когда вы собираетесь исправить надоедливое уведомление "Handling Theme", которое постоянно появляется на моем 6T? Это происходит с момента обновления 10.3. [/ QUOTE]
    You have written to the user forum. Your question is best addressed to OnePlus support. Read a couple of pages before your message, there is advice on how to make this notification almost invisible.
    Auristic likes this.
  4. P1509138096585
    Cupcake Mar 6, 2020
  5. Z1563257973696
    Cupcake Mar 6, 2020
    Z1563257973696 , via OnePlus 6 , Mar 6, 2020 :
    Not fixed.
    unable to send any photos to whatsapp from camera gallery
  6. Prem 24
    Prem 24 , via OnePlus 6T , Mar 6, 2020 :
    My cousins are using OnePlus 7 and 7T but they are not facing issue like IAM facing issue one my OnePlus 6T
    it doesn't seem Android 10 problem
  7. J1583483147508
    Cupcake Mar 6, 2020
    J1583483147508 , Mar 6, 2020 :
    I updated 10.3.2 Today and I am not getting network on my mobile. I checked my sim with other devices and it perfectly works fine there. What kind of an update is this???
  8. Abhishek_Singh_2
    Honeycomb Mar 6, 2020
    Harshk4889 likes this.
  9. W1557160892925
    Froyo Mar 6, 2020
  10. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 6, 2020
    Caomhin , via OnePlus 6T , Mar 6, 2020 :
    Go to the link below, choose your phone model and download the installation file. Follow the instructions on the website to manually install 10.3.2
    https://www.oneplus.com/support/softwareupgrade
    AmritRajiva likes this.
  11. Caomhin
  12. Caomhin
    Reset your Mobile Network
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
  13. Caomhin
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    See if this helps.
    P1509138096585 likes this.
  14. manishtomar116
    Cupcake Mar 6, 2020
  15. Caomhin
    You can minimise the app notifications, and possibly silence any sound it makes.
    Go to Settings>Apps and notifications>All x apps>3 dot menu>Show system apps>Android System>Notifications|>FG OPThemes...
    Select Other less important without sound and Vibration.
    Should reduce intrusions.
    ironass likes this.
  16. Caomhin
    What's the error?
  17. Lordson007
    Cupcake Mar 6, 2020
    Lordson007 , Mar 6, 2020 :
    Inverted images in notifications.....
    When I use my phone in dark mode, the notifications are inverted in colour...This is really annoying.... Please fix this [e]1f62d[/e]
  18. Master_TC
    Jelly Bean Mar 6, 2020
    Master_TC , Mar 6, 2020 :
    Just paste it direct into the internal storage. That's your root directory. Once done, install from the local upgrade option.
  19. Twiny
    Eclair Mar 6, 2020
    Twiny , Mar 6, 2020 :
    72 hours in since updating to OOS 10.3.2 and I've got to admit all is good. Thanks OnePlus!!!
    Alex Sem, danycmoi and Caoimhín like this.
  20. manishtomar116
    Cupcake Mar 6, 2020
    manishtomar116 , via OnePlus 6 , Mar 6, 2020 :
    move installation in the root directory and i already paste the package in root directory but its not detected
