181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. manishtomar116
    Cupcake Mar 6, 2020
    manishtomar116 , via OnePlus 6 , Mar 6, 2020 :
    i already done that but its not detected the package and i tried this process 3 times.
  2. Caomhin
    Marshmallow Mar 6, 2020
    Caomhin , via OnePlus 6T , Mar 6, 2020 :
    Does the file name end in .jar if so delete the .jar, as it should end in .zip
  3. deep.12
    Cupcake Mar 6, 2020
    deep.12 , Mar 6, 2020 :
    worst update ever oneplus
    it freezes my payment apps as well youtube
    work on it worst user experience
    A1550387522048 likes this.
  4. mathewthomas84
    Froyo Mar 6, 2020
    mathewthomas84 , via OnePlus 6 , Mar 6, 2020 :
    Infact, I had the same scenario and issues. I was able to see the photos and videos available in the internal storage (even though I was not able to view them using the gallery app or Google photos app since they were getting force closed), I did a System reset (as in the screen shot, excluding the internal storage) and set up my phone, backed up my applications from Google, then all seems fine, no force closed apps and am able to see the photos and videos through the apps.
    Caomhin likes this.
  5. Ketan2k18
    Cupcake Mar 6, 2020
    JAGADISH BHATTA, Caomhin and ironass like this.
  6. Manav_Majmudar
    Cupcake Mar 6, 2020
  7. Pavan12345678
    Cupcake Mar 6, 2020
  8. A1550387522048
    Gingerbread Mar 6, 2020
  9. Yogesh Nagrath
    Cupcake Mar 6, 2020
  10. E1527950091024
    Donut Mar 6, 2020
    E1527950091024 , Mar 6, 2020 :
    even i am also facing the same issue while trying to send photos...need to restart the phone
  11. E1527950091024
    Donut Mar 6, 2020
    when I am searching for application, search Letters are not showing..after 10.3.2 update.. please fix
  12. kartheekmavuluru
    Cupcake Mar 6, 2020
    E1527950091024 likes this.
  13. Alex Sem
    Alex Sem , via OnePlus 6T , Mar 6, 2020 :
    They offer you the most reliable way - update from the official site. Only full updates are published on the site. If it’s so important for you to upgrade partially, then either wait for OTA, or use Oxygen Updater, setting it to partial update.
  14. A1550387522048
    A1550387522048 , via OnePlus 6 , Mar 6, 2020 :
    okay. so I wait for a few more days and after I will do from official. oxygen Updater publish partial.yes..however is it safe and correct I am not sure.if sure Updater is a correct way I can do via it because I have its app.
  15. Muhammad_Kashif_bahl
    Muhammad_Kashif_bahl , via OnePlus 6 , Mar 6, 2020 :
    currently i am beta 5, and using this dual channel feature, and if i update my oneplus 6 to 10.3.2, after update this feature will b same or removed or not...???
    anyone here using 10.3.2 please tell me either dual channel feature is available or not in wifi and network setting.. pleade also share screen shot...
  16. Caomhin
    It is the full file, but it will upgrade over you current version, applying what is necessary. There is nowhere that I know of where you can download the Incremental file.
    XDA have one, but it appears to be about 80mb which looks like the wrong file.
  17. Muhammad_Kashif_bahl
  18. Caomhin
  19. A1550387522048 likes this.
  20. Caomhin
    Try the following to see if it rectifies the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
