181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Chandrashekhar K
    Cupcake Mar 8, 2020
  2. jayeshbhatt
    Cupcake Mar 8, 2020
  3. Alex Sem
    Gingerbread Mar 8, 2020
    Secsboma likes this.
  4. Gokul7373
    Honeycomb Mar 8, 2020
  5. Ashishrazz
    Cupcake Mar 8, 2020
  6. K_deep
    K_deep , via OnePlus 6T , Mar 8, 2020 :
    ਮੈਂ ਤਾਂ ਆਪਣਾ 6T oxygen updater ਨਾਲ update ਕਰ ਲਿਆ
  7. manikanakwalia
    Cupcake Mar 8, 2020
  8. Last edited: Mar 8, 2020
    Caoimhín likes this.
  9. Last edited: Mar 8, 2020
  10. Deactivated User
    Mar 8, 2020
  11. mohd_areeb , via OnePlus 6 Mirror Black , Mar 8, 2020 :
    Sandmonster
    I locally upgraded from offical oneplus link u have given. after updating why there is no change log showing ?​
    It's because maybe, the log shows if we update through ota,
    since you updated manually and few days ago I was facing some issues after updating through ota, and then I updated manually by flashing thr full ota.
    no need to worry about the changelog/update log if the manual updation is successful.
    if you face battery drain or any other issues just wipe cache data from recovery and for the battery, Fully discharge your device and leave it overnight, and then do a full charge in the morning without powering on the Device.
    i did the same today and the battery backup (sot) is good till now.
    there's also no log showing in my device as well.
    Deactivated User likes this.
  12. S1579789146905
    Cupcake Mar 8, 2020
    S1579789146905 , Mar 8, 2020 :
    Hello
    I'm new user for OnePlus
    now I have OnePlus 6T when I using camera on WhatsApp the photos coming warmish like yellowish... can u fixed it pls ???
  13. Ashishrazz
    Cupcake Mar 8, 2020
  14. Ashishrazz
    Cupcake Mar 8, 2020
  15. Tee_Eee_Bee
    Ice Cream Sandwich Mar 8, 2020
    Tee_Eee_Bee , via OnePlus 6T , Mar 8, 2020 :
    Ashishrazz
    I just downloaded but I couldn't get any local update in update sections
    Have you made sure the file is in the root directory (the same as base level internal storage) and removed the ".jar" file extension by editing the file name in file manager?
    Caoimhín, ironass and rhyd1am like this.
  16. rhyd1am
    KitKat Community Expert Mar 8, 2020
    Caoimhín and ironass like this.
  17. Ashishrazz
    Cupcake Mar 8, 2020
  18. Predator_xx777
    Cupcake Mar 8, 2020
    Predator_xx777 , via OnePlus 6 , Mar 8, 2020 :
    Hi all,
    can someone confirm if COD mobile can be used without issues with this update?; because I on previous version I can not play two times in BR mode continuously, so I've downgraded to 9.0.9 version, and before update should be good to know if the issues was solved or not, thanks.
