181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Thomas Shimko
    Eclair Mar 9, 2020
    Thomas Shimko , via OnePlus 6T , Mar 9, 2020 :
    Why not write it? Less responsibility for them. The same goes for downloading automatic updates. They are the same files. The difference is only that they push you a link to auto download the rom file and also you get the changelog file.
    The rom has some fail-safes so if the file is damaged it shouldn't install.
    N1539961316860 likes this.
  2. Tee_Eee_Bee
    Ice Cream Sandwich Mar 9, 2020
    Tee_Eee_Bee , via OnePlus 6T , Mar 9, 2020 :
    Sumeetdhurmekar
    where is the update??​
    H1535106412349
    not received yet​
    Go to your local OnePlus support page (select your preferred phone model) and download.
    Make sure the file is in the root directory of your device, and if needed, exit the file name in file manager to remove the ".jar" from the file name.
    You can then install via local upgrade.
    Artemus. and Caoimhín like this.
  3. ramkr1607
    Gingerbread Mar 9, 2020
    ramkr1607 , via OnePlus 6 Midnight Black , Mar 9, 2020 :
    nothing dude..just wait
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 9, 2020
    Artemus. likes this.
  5. Caomhin
    Caomhin , via OnePlus 6T , Mar 9, 2020 :
    Other than trying a full factory reset after backing up all your date. I would suggest contacting OnePlus support directly.
    Scroll down the page for contact details.
  6. KuFain
  7. Alex Sem
    Alex Sem , Mar 9, 2020 :
    [QUOTE = "KuFain, post: 21395525, member: 1535526"] быстрый вопрос: мне нужно 10.3.1 перед обновлением до 10.3.2, обновлением с Android 9? [/ QUOTE]
    To upgrade to Android 10 with Android 9, there must be version 9.0.9 for OnePlus 6 and 9.0.17 for OnePlus 6t. This is a prerequisite. Then you can download the full update file from the OnePlus website and update locally. Or wait for OTA.
  8. manishrsilwal
    Donut Mar 9, 2020
    manishrsilwal , via OnePlus 6T , Mar 9, 2020 :
    The camera app is lagging so much. Just switched to Pro Mode from normal and it got stuck for a while. Then clicked a photo which was taking multiple clicks.
  9. Ricanstyle
    Froyo Mar 9, 2020
  10. Caomhin
    Update your camera to the latest version. See if fixes the issues you experience.
    https://www.apkmirror.com/apk/onepl.../oneplus-camera-3-8-109-android-apk-download/
    And Download and install OnePlus Camera Service
    https://www.apkmirror.com/apk/onepl...s-camera-service-2-2-10-android-apk-download/
  11. manishrsilwal
    Donut Mar 9, 2020
    Seems like the issue is solved. Thank you so much. One more question, what about the future updates of the camera app? Will it arrive in the Playstore or need to download it from 3rd party site?
    Caoimhín likes this.
  12. deep.12
    Cupcake Mar 9, 2020
    deep.12 , Mar 9, 2020 :
    i want to know that what is this application running in the background which is (-5) application
  13. Caomhin
    Currently the OnePlus Camera is not available in the Playstore. It seems to only update via OOS build updates, but newer Camera apps do become available, this is the same for other apps as well nit posted or delayed posted in the Playstore.
    No idea why that's is.
    The OnePlus Gallery and Launcher apps are newer versions in ApkMirror, than those available in the Playstore.
    You will get more info in this article about OnePlus and the way it handles Playstore updates for its own apps.
    https://www.androidpolice.com/2020/...ger-on-the-play-store-for-faster-updates/?amp
    manishrsilwal likes this.
  14. Caomhin
  15. deep.12
    Cupcake Mar 9, 2020
    bro i have seen it but this is something unusual
  16. Caomhin
    There is a Hotspot app on the phone, if you disable your Hotspot you will see that the - 5 will no longer utilise battery.
    Its a badly named identifier.
    This question had been asked and answered many times on these forums.
    The Answer is its the identifier for the Hotspot feature.
    Artemus. and drl431 like this.
  17. Nivin Sheru
    Cupcake Mar 9, 2020
  18. Auristic
    Lollipop Mar 9, 2020
    Auristic , Mar 9, 2020 :
    What about your reading problems?
    jrsamp, rhyd1am, Caoimhín and 2 others like this.
  19. rnautiyal
    Froyo Mar 9, 2020
  20. Nivin Sheru
    Cupcake Mar 9, 2020
