181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Caoimhín
    OnePlus 9 Series Expert Community Expert Mar 9, 2020
    Caoimhín , via OnePlus 6T , Mar 9, 2020 :
    The file should end in .zip, it should be placed in the root storage, NOT in a folder.
    When you go into Settings, System, System Updates, click the gear wheel, top right corner oft he screen. Choose Local Upgrade. It should appear in the list to install.
    Naveen_006 likes this.
  2. A1550387522048
    Honeycomb Mar 9, 2020
    A1550387522048 , via OnePlus 6 , Mar 9, 2020 :
    thanks. yes I did do more times but it seems for a millisecond and disappear...anyway .The update 10.3.2.arrived after I downloaded full from op website. just like a joke..
    Caoimhín likes this.
  3. King2468
    Gingerbread Mar 9, 2020
    King2468 , Mar 9, 2020 :
    just update to 10.3.2 today. However, handling theme still exist. The fingerprint bug of op6 is not fixed
  4. Jimbo the Great
    Ice Cream Sandwich Mar 9, 2020
    Jimbo the Great , Mar 9, 2020 :
    Good joke. 😆
    Have you tried the Oxygen Updater app to speed up the updates?
    I realize that this wont help you now, but maybe in the future.
    No joke. 🙂
    VincentAbee and A1550387522048 like this.
  5. aalsiBanda
    Gingerbread Mar 10, 2020
  6. Gokul7373
    Honeycomb Mar 10, 2020
    Gokul7373 , via OnePlus 6T , Mar 10, 2020 :
    No way because it is the feature given by OnePlus.If the time shows 1 number in any hours it will show in Red
  7. Shaileshmdr
  8. Y1547161782974
    Froyo Mar 10, 2020
  9. Santhosh1997
    Donut Mar 10, 2020
  10. bramgoodwin
  11. N1539191125062
    Donut Mar 10, 2020
  12. SyedAbdulMajeed
    Cupcake Mar 10, 2020
  13. SrAjeSwarI
    R1565438083151 and Naveen_006 like this.
  14. Bobs Smart
  15. Ashhar_Arbab_Hashmi
    N1539191125062 likes this.
  16. abhijituk
    abhijituk , via OnePlus 6T , Mar 10, 2020 :
    Im still sticking with Android 9 just because of slow navigation in android 10. Android 9 has superfast and handy navigation, why complicate it in android 10? There should be an option to choose the navigation the user wants.
  17. sman786
    Froyo Mar 10, 2020
    sman786 , Mar 10, 2020 :
    What was the issue ? i received this update, i can check if you want and update here
  18. Tee_Eee_Bee
    Ice Cream Sandwich Mar 10, 2020
    Tee_Eee_Bee , via OnePlus 6T , Mar 10, 2020 :
    abhijituk
    There is an option - you can use 3 button navigation or gestures in A10.
    Settings -> Buttons & Gestures -> Navigation bar & gestures and choose Back, Home, Recents if you want the buttons.
  19. sman786
    Froyo Mar 10, 2020
    Bro you have to upgrade it. There are no options unless you dont wanna root your phone. your device's security patches are important. so you have to install it.
    A1550387522048 and Sanketshejwal like this.
