181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 10, 2020
    Caomhin , via OnePlus 6T , Mar 10, 2020 :
    It's not a Bug, it's coded that way.
    However entirely up to you if you want to show less of the Android Theme messages. That's how you do it.
  2. arodhan
    Eclair Mar 10, 2020
    arodhan , via OnePlus 6T , Mar 10, 2020 :
    after installing oxygen 10, battery draining has been observed very high. even when my phone is switched off, it keeps getting down. in 15 hours it lost 17% as i observed today.
  3. Caomhin
    That's less than 1% per hour if the phone is running, and your battery will still run down slightly over time when switched off
    What's the SOT like from full charge to below 50% during normal usage?
  4. J1562997001664
    Donut Mar 10, 2020
  5. arodhan
    Eclair Mar 10, 2020
    i lost 17% in 15 hours when it was switched off. it gets around 4-6% when my phone is on but idle. in case of game play it drains empty within 3.75 - 4 hours if earphone is used. in normal but not continuously usage like using social media, phone calls, etc. it consumes around 55 - 60% in around 7-8 hours.
  6. Reimps
    Cupcake Mar 10, 2020
    Reimps , Mar 10, 2020 :
    Please find your way to fix notification settings reverting back to 'app provided sound' after manually selecting 'none'. please
  7. Caomhin
    I am getting good SOT, usage time.
    Nearly 2 hours for 12% SOT. I generally get approx 10 to 12 hours SOT on a full charge, but no Gaming, don't even have a game installed. I don't switch the phone off, so no idea what it would be like.
    YedarePrathamesh and drl431 like this.
  8. A1574345242809
    A1574345242809 , Mar 10, 2020 :
    i tried that but hasn't gotten rid of it
  9. Artemus.
    Community Hero 2020 Mar 10, 2020
    Artemus. , Mar 10, 2020 :
    You can't get rid of it, it's.built into the ROM. All his suggestion does is makes it less noticeable.
    Auristic, drl431 and Caoimhín like this.
  10. narceoneplus2
    Ice Cream Sandwich Mar 10, 2020
    narceoneplus2 , Mar 10, 2020 :
    Has anyone figured out how to get Google Pay to work on the OnePlus 6T T-Mobile variant converted to the international version ever since the update to Android 10? Has anyone tried converting back to T-Mobile's Android 10 update and then converting back to Android 10 the international version?
    In the meantime, I have already contacted OnePlus Support 3 times. I received two responses saying that the next update will address the issue. However, that was exactly 3 updates ago. I am not rooted nor is my bootloader unlocked. I simply just converted to the stock international version. This issue did not exist when I originally converted my device while running Android 9. However, once I received the update to Android 10, Google Pay stopped working and I no longer pass CTS. I found this out when I downloaded a Root Checker app. If anyone has any insight regarding this it will be much appreciated. Have a great day!
  11. Caomhin
    You would have to use the proprietary TMobile version of Android 10 on a TMobile carrier phone to ensure your device is certified.
    Essentially the Bootloader in TMobile is different to the International version and any conversion to a Global version will break the fundamental security, thereby negating the certification.
    kjjm, drl431 and Artemus. like this.
  12. Notorious18
    Notorious18 , Mar 10, 2020 :
    this update is good but it has many bugs and needed fixs as my playstore stop working,all the data's are gonna except a few as I downloaded it from playstore I need some help if any one can help pls help me resolving this issue . tq
    Dear OnePlus
  13. Caomhin
    Try the following,
    Clear the App info Cache and App info Storage for all 4 items
    Google Playstore
    Google Play services
    Google Services Framework (Search in Setting for this)
    Google App
    Restart the phone.
    See if this rectifies the Playstore issue.
  14. narceoneplus2
    Is this new? The reason I ask is that when I originally converted my device, I was running Android 9 at the time and the problem was not there. Everything was fine. However, once I updated to Android 10, the problems began and still continues. I have already tried deleted the cache to the Google Play Store, Google Play Services, Google Services Framework and the Google app but the issue persists.
  15. King2468
    Gingerbread Mar 10, 2020
    King2468 , Mar 10, 2020 :
    i update from 10.0.1 to 10.3. This bug exist.
  16. Ellistar
    Honeycomb Mar 10, 2020
  17. Caomhin
    Android 10 brought in more stringent security measures for phones and the software environments. This has caused the effect you see regarding financial payment apps, and in many cases online banking as well.
    Android 10, has fundamentally changed how a device is seen to be certified.
    It's not just on your phone, many phones have the same issue. But essentially, you will currently need a TMobile version of Android for your phone.
    Unless OnePlus bring out a fix for this, there is now way around it as far as I know.
    Other phones with similar issues.
    https://www.google.com/search?q=pho..._oAhXwShUIHTluD68QpwV6BAgNEAk&biw=412&bih=805
    Artemus., kjjm and drl431 like this.
  18. Q1541181857158
    Q1541181857158 , Mar 10, 2020 :
    guys ,when I am on the landscape mode,I am not able to go back directly to main screen,middle pull gesture stop working at that time, please check
  19. X1536579772418
    X1536579772418 , Mar 10, 2020 :
    I am unable to connect with WiFi post update. please let me know if anyone else is facing the same issue.
  20. pavlidisc
