249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. rhyd1am
    Jelly Bean Apr 30, 2020
    rhyd1am , via OnePlus 6T , Apr 30, 2020 :
    Always people here who are happy to help. It's just a case of asking for help instead of demanding help like so many seem to do 🙂
    Caomhin and Artemus. like this.
  2. Prem 24
    Gingerbread Apr 30, 2020
    Prem 24 , via OnePlus 6T , Apr 30, 2020 :
    Yes bro u are right there is no stability in software many bugs as u said is being faced daily by us but there is no update for it still we can't use it properly and OnePlus is completely focusing on new device
    ratansuthar00 and iamrj like this.
  3. Artemus.
    Nougat Apr 30, 2020
    Artemus. , Apr 30, 2020 :
    The updates are perfectly stable, people just need to learn common sense and how to maintain their phones without running here and wanting everything spoon-fed to them. Google exists, you know.
    Skoreykom, Caomhin and rhyd1am like this.
  4. Caomhin
    Marshmallow Apr 30, 2020
    Caomhin , via OnePlus 6T , Apr 30, 2020 :
    Oh here we go, one instance of a phone not functioning, when 10s of thousands of others have updated via Oxygen Updater and the install is working fine, including mine using the same method.
    Elaborating on what bugs you have instead of some random statement might help.
    kjjm likes this.
  5. Caomhin
    To be honest Beta is fine, when both channels are running, the issue was really the way it was communicated once the Beta Channel closed. And then releasing a stable update 2 days later, kinda messed it up a bit. But resolutions were found, and we'll done to those who found them.
    Am glad you got sorted though. Happy days. [e]1f601[/e][e]1f44d[/e]
  6. Caomhin
  7. Caomhin
    What bugs are you currently facing, many on here have fixed many issues by just highlighting with exact details, as to what's happening.
    Prem 24 likes this.
  8. themountaineagle
    Froyo Apr 30, 2020
    themountaineagle , via OnePlus 6T , Apr 30, 2020 :
    I am facing problem with face unlock. Sometimes face unlock doesn't work.
    When you go to setting tab it takes 3 to 4 second to show the settings
    when You open some of application. it freezes app for sometime
    spontaneous flickering of brightness is higher thn before in auto mode.
    Prem 24 likes this.
  9. Karan_sharmaa
    Honeycomb Apr 30, 2020
    Caomhin likes this.
  10. Prem 24
    1) While video calling wierd colours pop up something blue
    or yellowish
    2) Devices heats up too after the update in normal usage also
    3) Battery is draining
    4) Still Notification from application in notification area while tapping on it doesn't opens the application it's since I purchased the phone
    5) OnePlus weather application logo is not visible
    6) Sometimes UI lags it's random
    This are the few issues which I am facing .
    and all are repeated and reported to OnePlus but no solution as know and did all the steps provided bu OnePlus also
    iamrj and themountaineagle like this.
  11. Prem 24
    Same issue are been faced by me also
    themountaineagle likes this.
  12. Caomhin
    Okay, I have 3 suggestions.
    1. Clear all screen locks, pin, Fingerprint face, the whole shebang.
    Then clear all Smart Locks as well.
    Reboot the phone.
    Then setup face unlock only, see if this works for you.
    2. For all the Lag and Freeze issues.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    3. For flickering
    Turn on or off DC Dimming, whichever state its in do the opposite.
    Also Turn on or off Ram Boost. Try a combination of both.
    Set display Calibration to AMOLED Wide Gamut and set the Cool Warm slider as you would like it.
    See if any or all of the above help.
    rhyd1am likes this.
  13. Caomhin
    Prem 24 likes this.
  14. Caomhin
    Also clear Weather app App info Cache and and App info Storage.
  15. Caomhin
  16. Karan_sharmaa
    Karan_sharmaa , via OnePlus 6T , Apr 30, 2020 :
    i really wanna know this
    are you working for OnePlus?
    coz I've always seen your post here on regular basis, u are always helping others n sorting out there problems which is nice... 😬
    ironass, Caomhin and rhyd1am like this.
  17. Monikagoyal00
    Caomhin likes this.
  18. Caomhin
    Karan_sharmaa
    coz I've always seen your post here on regular basis, u are always helping others n sorting out there problems which is nice... 😬​
    No, am just a user same as you, I just do this as a hobby. Worked in It for years, am currently in lockdown so this keeps the mind going. I don't get paid in anyway shape or form.
    I just like to see that people end up using their phones the best way possible.
    It costs nothing, and it fills my day. I do it elsewhere as well, I find it fun, and if someone comes back and says thanks it was fixed and maybe even sometimes not, its the satisfaction that an attempt was made.
    Have been that person who required help a long time ago, and people were willing to do that. So you might say it's paid it forward.
  19. Caomhin
    Use 3rd party tool Oxygen Updater from playstore, and in Settings, select Full Update as update method [e]1f44d[/e]
    Artemus. and ironass like this.
