250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. lipu488
    Cupcake May 1, 2020
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 1, 2020
    Caomhin , via OnePlus 6T , May 1, 2020 :
    Surjeetsingh790
    Gcam crashes most of the times.
    Is there any stable version for GCam?​
    You can try this camera update to the latest version. See if fixes the issues you experience.
    https://www.apkmirror.com/apk/onepl.../oneplus-camera-3-10-17-android-apk-download/
    NB. Do NOT install Version 4 as it will not work on 6 series phones. I have tested 3.10.17 and it works fine.
    And Download and install OnePlus Camera Service
    https://www.apkmirror.com/apk/onepl...s-camera-service-2-2-12-android-apk-download/
    GCam
    Dev Marco Gcam integrated XML files for 6 series phones.
    I have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
    Auristic likes this.
  3. Auristic
    Lollipop May 1, 2020
    Auristic , May 1, 2020 :
    You can get it anytime if you read this thread...
    Caomhin likes this.
  4. Caomhin
    So the fact they have just released a new stable update, which functions extremely well. Suggests to you OP have forgotten all about ya.
    Ah here, lad, you need to get a perspective on time dude, weekly updates are not a thing. They are Bi monthly, as in every 2 months.
    Sit back, relax and enjoy your superb OnePlus experience. Get that Friday feeling.
    [e]1f601[/e][e]1f601[/e][e]1f44d[/e]
  5. Artemus.
    Community Hero 2020 May 1, 2020
    Artemus. , May 1, 2020 :
    What you did... was the same as packing up your essentials and forgetting to move them into the new house. Your data is now gone because you failed to move them.
    ironass, Auristic and Caomhin like this.
  6. clilsonkj
    Froyo May 1, 2020
  7. Caomhin
    Reset your WiFi adapter
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    See if that helps.
  8. clilsonkj
    Froyo May 1, 2020
    clilsonkj , via OnePlus 6T , May 1, 2020 :
    I did factory reset still have the issue
  9. U1513149367412
    Honeycomb May 1, 2020
    U1513149367412 , May 1, 2020 :
    after disabling those apps what for ur using the phone then lol...those are thr basic which phone should have
    MercyKiller69 likes this.
  10. Stark0207
    Eclair May 1, 2020
    Stark0207 , via OnePlus 6T , May 1, 2020 :
    priority
  11. I1548089682366
    Donut May 1, 2020
    Caomhin likes this.
  12. Caomhin
    If you have done a full proper reset, then I would suggest the following.
    You can contact OnePlus support directly for more information on your issue. Scroll down the page for contact/chat details.
  13. Pepa1977
    Froyo May 1, 2020
    Pepa1977 , May 1, 2020 :
    Hi on OnePlus 6 does not work when portrait mode freezes 3.10.17
  14. FaleshC
    KitKat May 1, 2020
    FaleshC , May 1, 2020 :
    because that's not the official camera app version for OnePlus 6.
    and that's what you get for manually updating system apps not meant for your device.
    OnePlus 6 has 3.8.114 camera version on 10.3.3
    so uninstall the updated camera version.
  15. FaleshC
    KitKat May 1, 2020
    it depends on OnePlus whether to include any feature in major or minor updates.
    oh, they said so in feedback. well, its good to hear. lets hope they do work on it and push it as soon as possible.
    mayrsona and Ajay_ydv like this.
  16. Pepa1977
    Froyo May 1, 2020
    Yes, that's why I pointed it out 😉
  17. Caomhin
    Pepa1977
    Hi on OnePlus 6 does not work when portrait mode freezes 3.10.17​
    Clear both the Camera App info Cache and App info Storage, see if that helps.
    Also clear you OnePlus Launcher App info cache as well.
  18. Caomhin
    It's working fine on my 6T on 10.3.3 with Oneplus Launcher 4.2.2.
    It can also be uninstalled at any time, by going to Camera App info, click 3 dots, choose uninstall updates.
    Compared to some of the crap people put on their phones, at least this is official and will work on a properly working phone.
  19. Pepa1977
    Froyo May 1, 2020
    Thanks have it just like you, and it still gets stuck on when you run portrait mode.
  20. Caomhin
    ironass likes this.
