249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Artemus.
    Nougat May 1, 2020
    Artemus. , May 1, 2020 :
    Downgrading is completely up to you. As for the background apps, don't think I've had this issue.
    drl431, Auristic and Caomhin like this.
  2. K1542712979609
    Froyo May 1, 2020
    K1542712979609 , via OnePlus 6T , May 1, 2020 :
    is there anyway that I can solve this issue?
  3. K1542712979609
    Froyo May 1, 2020
    I've started encountering this issue since after using oxygen updater and obtaining 10.3.2
  4. Artemus.
    Nougat May 1, 2020
    Maybe a screen recording could help explain the problem?
  5. K1542712979609
    Froyo May 1, 2020
    it occurs without pattern and it just occurs for a split second. if I were to have it recorded it would require me to keep screen recording on throughout my usage.
  6. DevaDcruz
    Froyo May 1, 2020
  7. Caomhin
    Marshmallow May 1, 2020
    Caomhin , via OnePlus 6T , May 1, 2020 :
    K1542712979609
    so should I go down to 9.0.17 or 10.3.2? also do you face the problem where when trying to clear the background apps, for a split second the apps switches with the one beside it? happens to me and I always end up clearing an app that I don't want to.​
    Have you tried a full factory reset with steps I posted, might be a better way to try. See if that improves the issues.
    Auristic and Artemus. like this.
  8. rhyd1am
    Jelly Bean May 1, 2020
    rhyd1am , via OnePlus 6T , May 1, 2020 :
    The other version you are referring to is not meant for the 6 series of devices. The users you see using it have side loaded it.
    Auristic, Caomhin and Artemus. like this.
  9. Caomhin
    That's right 4.4.2 is off the 7 or 8 series.
    I have it working on mine and most others who have say it works great, downloaded from ApkMirror, however a few say it's not working for them, but you can uninstall it if it doesn't work correctly.
    Auristic, Artemus. and rhyd1am like this.
  10. DevaDcruz
    Froyo May 1, 2020
    DevaDcruz , via OnePlus 6T , May 1, 2020 :
    Can you give me the launcher link for Oneplus 6T?
  11. Caomhin
  12. T1539496809178
    Gingerbread May 1, 2020
  13. dany.74
    Cupcake May 1, 2020
    dany.74 , May 1, 2020 :
    hello same problem the WiFi connects and disconnects continuously !!!!
    clilsonkj likes this.
  14. Caomhin
    New feature for OnePlus Gallery.
    OnePlus Gallery v3.11.2 adds a handy Google Lens
    This 3.11.2 update doesn’t add a lot of extra features, with just a few extra app optimizations and bug fixes. As far as a Google Photos replacements go, the OnePlus Gallery is a really solid alternative for those with a OnePlus device.
    https://9to5google.com/2020/05/01/oneplus-gallery-google-lens/
    OnePlus Gallery 3.11.2
    https://www.apkmirror.com/apk/onepl.../oneplus-gallery-3-11-2-android-apk-download/
    rHITkM, kjjm, Auristic and 1 other person like this.
  15. clilsonkj
    Froyo May 1, 2020
  16. Diptesh6384
    Cupcake May 1, 2020
  17. Caomhin
    Diptesh6384 likes this.
  18. JAGADISH BHATTA
  19. iamrj
    Honeycomb May 1, 2020
    iamrj , via OnePlus 6 , May 1, 2020 :
    Hello guys,
    I'm sharing my lattest picture from oneplus just clicked few minutes ago please notice the picture it has no color tone has blur image if you notice eyes are also blur this how due to software issues camera lacks. Please check the image properly.
    No edit
    IOS: 2000
    Flash: No flash
    Aperture: f/1.7
    Model: ONEPLUS A6000
    OxygenOS: 10.3.3
    Kindly fix issues on camera day by day its is annoying all oneplus 6 & 6T
    Regards,
    iamrj
    Chosen_One and G_Dhanapal_mEPD like this.
  20. T1539496809178
    T1539496809178 , May 1, 2020 :
    Did you get the OTA update?
