250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. rhyd1am
    KitKat May 1, 2020
    rhyd1am , via OnePlus 6T , May 1, 2020 :
    Be rude not to grab a few beers while you're there. Since you're picking up the other essentials anyway [e]1f37b[/e]
    ironass, Caomhin and Artemus. like this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 1, 2020
    Caomhin , via OnePlus 6T , May 1, 2020 :
    Absolutely, while walking passed the locked up pub next door. One of these days I will make it home with the milk.
    Artemus. and ironass like this.
  3. rhyd1am
    KitKat May 1, 2020
    Should send her it for the milk. Hard work carrying that beer home 😅
    Caomhin, Artemus. and ironass like this.
  4. Runnerista , via OnePlus 6T Midnight Black , May 1, 2020 :
    It is a common issue on 6t OOS 10. I have the same damn thing even on 10.3.3 build. It can be related to Android 10 itself.
    https://www.xda-developers.com/andr...g-random-freezing-unresponsive-ui-issues/amp/
    Try to provide OnePlus team with a log.
    Dhruva006 likes this.
  5. Stark0207
    Eclair May 1, 2020
    Stark0207 , via OnePlus 6T , May 1, 2020 :
    you know man you are having great time comapred to me in this lockdown ...
    cheers !!
    thank you for the reply stay safe buddy .. !
    Caomhin, Artemus. and rhyd1am like this.
  6. Ajay_ydv
    Gingerbread May 1, 2020
    Ajay_ydv , via OnePlus 6 Mirror Black , May 1, 2020 :
    shut up Shaktiman
  7. Ajay_ydv
    Caomhin likes this.
  8. Ajay_ydv
    aap gyani so apka gyan, lekin murkhon ke smane mat bano anjan.
    you are the omniscient, so is your knowledge, but stop pretending in front of the dumb.
  9. Ajay_ydv
    B_Wrath
    @Ajay_ydv the notch problem in Android 10 is a global phenomenon. Google changed the way oem uses notch. It has set a list of guidelines in A10 which makes it hard for OEM to use the notch area while hide notch is set.
    That is the reason why the entire status bar comes down in A10 while it was not the case in A9.
    Now, apps like nacho notch and the what MIUI has done, will hide the notch colour to black on apps which don't use that, but apps which use the notch will continue using them.
    There is nothing oneplus can do about it unless Google let's them do it.​
    now that's an explanation and reply so I shouldn't rant about it. thanks and love from this side. [e]2665[/e]️[e]2665[/e]️[e]2665[/e]️
    B_Wrath likes this.
  10. Ajay_ydv
  11. rmendez011
    rmendez011 , via OnePlus 6T , May 1, 2020 :
    I never said it was an Issue, nor was it important. I'm saying that no one important at OnePlus will read what I'm asking an enable the icons. 🤨
    bjorg18 likes this.
  12. U1588360323785
    Cupcake May 1, 2020
    U1588360323785 , May 1, 2020 :
    damn it says I want to make Android 9.0.17 rotation from android 10 to local upgrade will not be done to the older version. don't tell me to give feedback.I've done it. it says I can do it with a computer. I DON'T HAVE A COMPUTER TO ANSWER THAT . LOOK, I DON'T HAVE A COMPUTER, I WANT TO MAKE THE TRANSITION FROM ANDORID 10.3.2 TO ANDORID 9.0.17.
  13. Artemus.
    Community Hero 2020 May 1, 2020
    Artemus. , May 1, 2020 :
    Why?
    drl431 and Caomhin like this.
  14. B_Wrath
    Nougat May 1, 2020
    B_Wrath , May 1, 2020 :
    WHY THE HELL ARE YOU SHOUTING!?
    If you want to rollback to pie, use the rollback package provided in the pinned thread by @ironass.
  15. ramesh.dilin
    Cupcake May 1, 2020
  16. rhyd1am
    KitKat May 1, 2020
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    There if it stops you shouting..... I'd hate for you to have to actually spend a little time and search for it yourself!
  17. Caomhin
    ROLL-BACK FROM CURRENT ANDROID 10 Beta or Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    Click the link for info on how to Downgrade.
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    If you can, you could try a Full Factory Reset to fix the issue. Steps below to Factory Reset the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Your phone will now restart and go through the Full reset cycle.
    And its always good practice to backup phone data before upgrading.
    drl431, ironass and rhyd1am like this.
  18. Caomhin
  19. rhyd1am
    KitKat May 1, 2020
    Caomhin likes this.
  20. Caomhin
    rhyd1am likes this.
