249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Caomhin
    Marshmallow May 1, 2020
    rhyd1am likes this.
  2. Caomhin
    Caomhin , via OnePlus 6T , May 1, 2020 :
    Announce by our Muppet Govt. No pubs open here till 10th August, another 14 weeks... [e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
    Phase Five (10 August)
    Pubs, bars, nightclubs and casinos, will be reopened where social distancing and strict cleaning can be complied with
    https://www.rte.ie/news/2020/0501/1136167-road-map-details/
    Ye are stuck with me longer.
    drl431 and rhyd1am like this.
  3. rhyd1am
    Jelly Bean May 1, 2020
    Caomhin likes this.
  4. rhyd1am
    rhyd1am , via OnePlus 6T , May 1, 2020 :
    I'm really sorry dude but all the answers you need have been given. You absolutely DO NOT need a computer to roll back. Although it appears having the answers given to you, and being able to understand and compute the given information are 2 different things.
    Perhaps it would be better to be less aggressive towards your fellow users in here. Hope somebody here is willing to help you 🙄
    Caomhin likes this.
  5. pvilarinho74 , via OnePlus 6 Mirror Black , May 1, 2020 :
    after all that aggressive display what I'm willing instead of help is to report him!🤔
    Caomhin and rhyd1am like this.
  6. Ravindraynk
    Cupcake May 1, 2020
  7. Caomhin
    Dude, you appear to have lost the plot. Only 3 or 4 posts, and you have become extremely insulting and hostile. If you don't want the help you requested, why exactly did you come here for.
    Are you a disgruntled Apple iPhone owner, and lost your way to the Apple forums.
    I will guide you, no problem.
    www.apple.com/support
    There ya go, now don't go away mad, just go away.
    rhyd1am likes this.
  8. rhyd1am
    It's a staged, random rollout. It goes first to a smaller group of "random" users, before going out to increasingly larger groups of users, and can take a couple of weeks to reach everyone.
    It's done this way to try to minimise the chance of any major bugs getting out there. Be patient and it'll soon reach your device 🙂
    Caomhin likes this.
  9. Caomhin
    As per first post at the top of the thread.
    Or you an be proactive and check the suggestions to get it sooner in the posts in this thread.
    Artemus. and rhyd1am like this.
  10. Caomhin
    Ya got me, the beer is slowing me down... [e]1f37b[/e][e]1f602[/e][e]1f37b[/e][e]1f602[/e]
    Artemus., ironass and rhyd1am like this.
  11. rhyd1am
    Night off the ale for me. This lockdown has involved way too much drinking for me. I'll catch up tomorrow 😅
  12. pankajDaman88604
    Cupcake May 1, 2020
    jitu@111 likes this.
  13. rhyd1am
    It can take up to a coupe of weeks for a staged rollout to reach all devices. I would imagine it shouldn't be too much longer till you receive the OTA.
    JAGADISH BHATTA, Caomhin and Artemus. like this.
  14. pankajDaman88604
    Cupcake May 1, 2020
    pankajDaman88604 , May 1, 2020 :
    So when did it coming
  15. Caomhin
  16. rhyd1am
    It started rolling out 6 days ago. As to when exactly you yourself will receive it, that's an impossible question for me to answer as I am just a user like yourself (and everyone else here).
    If you really can't wait, then you can download and install it via local upgrade yourself. Links to the updates are given plenty of times throughout this thread. 🙂
  17. pankajDaman88604
    Cupcake May 1, 2020
  18. Adriancorri
    Froyo May 1, 2020
    Adriancorri , May 1, 2020 :
    [QUOTE = "Caomhin, post: 21562874, membro: 1870372"] Questo è ciò che faccio in ogni versione.
    Esegui un ripristino di fabbrica completo di Cancella / Elimina tutti i dati.
    Questo ti ripristinerà su una nuova installazione di Android. Quindi dovrai eseguire il backup del telefono.
    Dopo aver eseguito il backup del telefono.
    Vai alle impostazioni,
    Sistema,
    Opzioni di ripristino,
    Abilita Cancella memoria interna.
    Quindi fare clic sul pulsante Elimina tutti i dati.
    Per ulteriori informazioni su come eseguire il backup del telefono, consultare le soluzioni qui.
    [e] 2b07 [/ e] ️ [e] 2b07 [/ e] ️ [e] 2b07 [/ e] ️NEXT [e] 2b07 [/ e] ️ [e] 2b07 [/ e] ️ [e] 2b07 [ / e] ️
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Miti di ricarica, batteria, prestazioni, cache e calibrazione della batteria eliminati
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/ [/ QUOTE]
    Scusi ma non mi pare normale che ogni aggiornamento devo fare reset di fabbrica c'è questa significa che ogni due mesi devo cancellare tutto mi pare assurdo.
  19. Caomhin likes this.
  20. Caomhin
    Marshmallow May 2, 2020
    Caomhin , via OnePlus 6T , May 2, 2020 :
    non devi farlo ogni aggiornamento, ho solo l'abitudine di farlo. Eseguo il sistema con l'aggiornamento per alcuni giorni per vedere se funziona bene. di solito lo fa. Ma poi ho ripristinato per vedere cosa può succedere. Mi piace testare e scoprire cosa può succedere o meno e se ci sono problemi da risolvere.
