249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. O1586331550560
    Eclair May 2, 2020
  2. ItsRavi25
    Ice Cream Sandwich May 2, 2020
    ItsRavi25 , via OnePlus 6T , May 2, 2020 :
    plz go through the forum..many people asked the same question...
    it's a incremental roll-out so it takes time to reach every devices.
    For faster update go to playstore and download Oxygen updater ..
    It is safe to install by the app..
    Caomhin likes this.
  3. ItsRavi25
    G_Dhanapal_mEPD, ironass and Caomhin like this.
  4. Pankaj vedi
    Eclair May 2, 2020
  5. Caomhin
    Marshmallow May 2, 2020
  6. Caomhin
    Caomhin , via OnePlus 6T , May 2, 2020 :
    There is no problem as you state on my phone. Must be only your phone.
    What exactly is happening with precise details, maybe someone can give you suggestions to try and alleviate the issues.
  7. rahulparur
    Froyo May 2, 2020
    G_Dhanapal_mEPD likes this.
  8. Master_TC
    Jelly Bean May 2, 2020
    Master_TC , May 2, 2020 :
    I loose 3-4% overnight with bluetooth, wifi and data always activated.
  9. AnimeshMiri
    Froyo May 2, 2020
    AnimeshMiri , via OnePlus 6T , May 2, 2020 :
    its normal for a phone to lose 3-4% at night......
  10. rahulparur
    Froyo May 2, 2020
    rahulparur , May 2, 2020 :
    Thats pretty decent. It is same for me if I restart the phone. But gradually increase and result in a drop of around 10 percent even if I put it in flight mode while sleeping. Restarting the phone fix the issue. Weird one. I am on 10.3.2.
    G_Dhanapal_mEPD and K_deep like this.
  11. C1569601707404
    Gingerbread May 2, 2020
    Caomhin likes this.
  12. Master_TC
  13. ItsRavi25
    try all that calibration thing..it is mentioned in this forum..it will helpful
    Caomhin likes this.
  14. Imrangnd
    Cupcake May 2, 2020
  15. K_deep
    K_deep , via OnePlus 6T , May 2, 2020 :
    same issue here
  16. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    drl431 likes this.
  17. Caomhin
    Try it on 10.3.3, there are posts on this thread showing how you can install it sooner than OTA. Then try the optimisation steps in the thread above.
  18. azampasha666
    Donut May 2, 2020
    azampasha666 , May 2, 2020 :
    after updated to 10.3.3 heating issues while playing pubg lot of heat
  19. Artemus.
    Nougat May 2, 2020
    Artemus. , May 2, 2020 :
    That's normal. PUBG is a horribly-optimized game so expect heat to generate.
