250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Federico Martin
    Gingerbread May 4, 2020
    Federico Martin , via OnePlus 6T , May 4, 2020 :
    Already do that but I want to revoke stock OP file manager and it isn't on the list
    Also if I enable show system app nothing happens.
  2. LegolasX
    KitKat May 4, 2020
    LegolasX , May 4, 2020 :
    well for starters its a system file manager app, that could be the reason you cannot revoke the ability to install unknown apps.
    frankly i don't see any issue in that, i mean if you don't use the app for installation it should be fine.
    i should check mine and see if that's how it is.
    Federico Martin likes this.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert May 4, 2020
    Caomhin , via OnePlus 6T , May 4, 2020 :
    Sorry could you clarify what you meant, do you mean long press icon and select from menu?
  4. Mithesh_k
    Froyo May 4, 2020
    Mithesh_k , via OnePlus 6T , May 4, 2020 :
    Hey! I don't see an option to uninstall or disable. so, how'd you do it?
    rohitkumar6889 likes this.
  5. [email protected]
    Honeycomb May 4, 2020
    [email protected] , via OnePlus 6T , May 4, 2020 :
    same here how to uninstall or disable files app and why is there two file manager🤕
  6. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator May 4, 2020
    Artemus , May 4, 2020 :
    Files is Downloads (Google Drive) and File Manager is... well, File Manager.
    JAGADISH BHATTA and Caoimhín like this.
  7. echelon9797
    Froyo May 4, 2020
    echelon9797 , via OnePlus 6T , May 4, 2020 :
    exactly. I was asking people about Files Go a.k.a Files by Google.
  8. P1512576257525
    Eclair May 4, 2020
  9. prkoparkar
    Froyo May 4, 2020
    prkoparkar , via OnePlus 6 , May 4, 2020 :
    long press the application icon. go to app info. now you can force stop etc. if you want.
  10. prkoparkar
    Froyo May 4, 2020
    install Google lens app from play store. on OP camera, point to the object, text etc you want to search via Google lens and long press in the camera view on the object. Google lens will apoeat
  11. Caomhin
    As per the first readable post, and answered a hundred times in here already.
    Or you can check the many posts with suggestions on how to get it manually sooner.
    Artemus likes this.
  12. Caomhin
    Go to Camera settings and enable Smart Content Detection. Then go back and long press the Camera on the screen to see Lens.
    K1542367714581 likes this.
  13. ItsRavi25
    Jelly Bean May 4, 2020
    ItsRavi25 , via OnePlus 6T , May 4, 2020 :
    Caomhin
    Sideload from ApkMirror, most find it works without issue on 6T ,a few have had issues. Which is weird as we all have the same OOS and Hardware.
    The additional Shelf and Recents App features are great. And I find it runs buttery smooth.
    OnePlus Launcher 4.4.2.
    https://www.apkmirror.com/apk/onepl...-2-200408114510-c7e96db-android-apk-download/
    I just want to know that while hiding notch the status icons( network,wifi, battery,etc) are showing inside the screen ..The icon should be in hiding area as it was in android 9 but not in android 10...
    Is it the system problem or launcher problem..
    Will new launcher version help me to fix this?
  14. Caomhin
    No that's the way the notch currently works, when you hide the Notch area. All the icons move down from top of the screen when you choose the option Show Notch area.
    The Android 9 option is not available in Android 10.
    Artemus likes this.
  15. ItsRavi25
    Thanks for you information..
    i also thought that it's system problem.
    Caoimhín likes this.
  16. Caomhin
    Artemus likes this.
  17. Ak.
  18. Caomhin
    Ak.
    The battery backup in this new update is seriously shit
    Might be on your phone, but your personalisation might have something to do with that.
    It's actually unbelievably good on 10.3.3.
    ironass, Artemus and G_Dhanapal_mEPD like this.
