249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Lelander2015
    Gingerbread May 5, 2020
    Lelander2015 , via OnePlus 6 , May 5, 2020 :
    we in North America always get it last.
  2. ironass
    Lollipop May 5, 2020
    ironass , May 5, 2020 :
    That NSA spyware doesn't just add itself you know. ;)
    Caomhin, Artemus., Auristic and 2 others like this.
  3. suresh9890
    Eclair May 5, 2020
  4. Tee_Eee_Bee
    Ice Cream Sandwich May 5, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 5, 2020 :
    As per the first post, it's a staged rollout, so you have to be patient and wait for it to show up.
    Or as mentioned many, many times before in this thread, you can use Oxygen Updater and download and install yourself.
    Caomhin, Artemus. and Auristic like this.
  5. Tee_Eee_Bee
    Well, that also explains why it takes so long here in Oz to get the updates - we're part of the 5 eyes organisation...... [e]1f601[/e][e]1f601[/e]
  6. mohanrajm
    Cupcake May 5, 2020
    mohanrajm , via OnePlus 6T , May 5, 2020 :
    hi
    yesterday night my op6T fall into water.. near to 10 seconds. when I got my mobile suddenly I make switch off my phone. and put into rice bag for 10 hr.. just now i turn on my mobile. still now I was not found any issues. if there future I will get any complaint or not.. pls help me
  7. nehagupta0023
    Cupcake May 5, 2020
    nehagupta0023 , via OnePlus 6T , May 5, 2020 :
    lucky you .. please do share your feedback after 7 days or so
  8. nehagupta0023
    Cupcake May 5, 2020
  9. nehagupta0023
    Cupcake May 5, 2020
    you can wait ... it will show up 10.3.3 soon
  10. goalie2002
    Eclair May 5, 2020
    goalie2002 , May 5, 2020 :
    The 6t is water resistant, so you're probably fine. Just a tip: it's been proven that rice doesn't help, it's a myth.
    mohanrajm likes this.
  11. goalie2002
    Eclair May 5, 2020
    You probably still have 10.3.2. wait until your phone gets 10.3.3.
  12. avalanch707
    Honeycomb May 5, 2020
    avalanch707 , via OnePlus 6T , May 5, 2020 :
    this is reason why they made , OnePlus 8 pro, so you can buy new one. I am wondering here that , how did it fell in the water..?
  13. Girish4444
    Eclair May 5, 2020
  14. G_Huynh_Tinh
    O1570636022470 likes this.
  15. Tee_Eee_Bee
    G_Huynh_Tinh
    After upgraded from open beta 6, google play store does not work. How to fix?​
    Solution is in the pinned post by B_Wrath at the start of the thread, also known as page 1.
    Caomhin, Artemus., ironass and 2 others like this.
  16. cyberman_5145
    cyberman_5145 , via OnePlus 6 , May 5, 2020 :
    got to applications >> search for Google Play service and also for play store. clear cache for both apps and restart your phone ... you should be fine and play store should work as intended
    G_Huynh_Tinh likes this.
  17. dhaveshs
    Cupcake May 5, 2020
    dhaveshs , May 5, 2020 :
    what the hell! after this update! battery is draining so fast! from 100 to 0 in just half day with min usage. wht the hell are u doing OnePlus! uhr products are getting worst day by day! very disappointing OnePlus.
  18. G_Huynh_Tinh
    G_Huynh_Tinh , via OnePlus Community App , May 5, 2020 :
    Thanks. I've just wiped my device. Now google play working fine.
    O1570636022470 and petertinh like this.
  19. Tee_Eee_Bee
    dhaveshs
    You could try this and see if it helps
    Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
  20. rhyd1am
    Jelly Bean May 5, 2020
    rhyd1am , via OnePlus 6T , May 5, 2020 :
    Have you actually looked at the battery usage to see which apps are using/draining the battery, thereby getting to the root of the problem?
    It's kind of difficult for anyone to help if you're just throwing out general statements! 🤷‍♂️
