249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Caomhin
    Marshmallow May 5, 2020
    Caomhin , via OnePlus 6T , May 5, 2020 :
    +44 is a UK prefix.
    ironass and Artemus. like this.
  2. ramesh.dilin
    Cupcake May 5, 2020
  3. Artemus.
    Nougat May 5, 2020
    Artemus. , May 5, 2020 :
    These numbers are from the UK.
    Caomhin likes this.
  4. Caomhin
    It looks like those messages with +44 are from the UK. +44 is the International dialling code for England, Scotland and Wales. UK.
    Artemus. likes this.
  5. ramesh.dilin
    Cupcake May 5, 2020
    ramesh.dilin , via OnePlus 6T , May 5, 2020 :
    ok now its safe or not is there any issue will comes future
  6. Caomhin
    No idea, do you communicate with people in the UK.
    Also check the 2 digits after the + on the other numbers and see if you can identify if the numbers are from countries you communicate with.
    International Dialling Country code lookup website.
    https://countrycode.org/
  7. iamrj
    Honeycomb May 5, 2020
    iamrj , via OnePlus 6 , May 5, 2020 :
    Yes. No issues. Don't worry at all folks!
    Caomhin and rhyd1am like this.
  8. C1549006646174
    Cupcake May 5, 2020
  9. Caomhin
    iamrj
    Dear Kythatsis,
    Kindly refer to my previous threads it might help you to understand more better i recommend please check it.​
    I did recommend using a Gcam to you before. Just wondering how that works out for you comparing pictures taken on stock OnePlus camera against Gcam.
    I find I use the Gcam more. As stock camera for me is fine in normal outside daylight. But I prefer Gcam for indoor shots.
    Let me know how that Gcam works out for you. They do have a lot more options to choose from built in.
    drl431, iamrj and rhyd1am like this.
  10. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    rhyd1am likes this.
  11. Artemus.
    Nougat May 5, 2020
    Can you link them please?
    drl431, Auristic and Caomhin like this.
  12. iamrj
    iamrj , May 5, 2020 :
    I do understand after all it's a mobile smartphone not a DLSR but according to lens which we have atleast we can have some better changes on pictures that's all i need not more then that. I use to get on oxygen os 5.1.11 those were the days when things are little bit okay then there is no option to arguing and creating list of thread also I'm very much kind if you notice my all threads i have personally never been harsh to anyone.
  13. Caomhin
    No argument at all, but our perspectives have changed as the hardware on newer phones gets better. So on these nearly 2 year old phones, we have to get the best out of them. And a modded Gcam allows us to do that.
  14. suvendudassd
    Cupcake May 5, 2020
  15. iamrj
    OnePlus 6 (Auto Flash)
    Gcam (Auto Flash)
    At times, from front its very clear but if you click any landscape/portrait sometimes white line and blurry image is seen just showing you the difference between both application.
    Caomhin likes this.
  16. Last edited: May 5, 2020
  17. VaibhavAMido
    Froyo May 5, 2020
  18. thesauravkarmakar
    Eclair May 5, 2020
  19. Caomhin
    Go through at least 2 full charge cycles, Android will be working in the background to optimise apps. So it can take a while to settle down. It's NOT instant. Patience is the key.
    ironass likes this.
  20. Caomhin
    Try the following.
    Go to Settings,
    System,
    Reset Options,
    drl431 and ironass like this.
