250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. prkoparkar
    Froyo May 5, 2020
    prkoparkar , via OnePlus 6 , May 5, 2020 :
    it is inbuilt. even without downloading lens app, it works.
  2. Virendra dhaka
    Froyo May 5, 2020
  3. Artemus
    Community Hero 2020 May 5, 2020
    Artemus , May 5, 2020 :
    Re-read the first post. Focus on the part that says "This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. Using VPN to download this build might not work as the rollout Is not based on regions and is randomly pushed out to a limited number of devices."
  4. St_Jacob
    Gingerbread May 5, 2020
  5. X1545479131591 likes this.
  6. Dharmraj Jeurgi
  7. rhyd1am
    KitKat May 5, 2020
    rhyd1am , via OnePlus 6T , May 5, 2020 :
    If I knew, if gladly tell you. It is one of the region specific features available in the shelf if in the right region I guess 🤷‍♂️
    Caoimhín likes this.
  8. PrAzAdnp , via OnePlus 6T Midnight Black , May 5, 2020 :
    this feature for what...is for sports updates or any other ?
  9. rhyd1am
    KitKat May 5, 2020
    As I mentioned, I don't know exactly what it is as it's not available where I live. I would guess it's for sports updates/scores but that's just my guess 🤷‍♂️
    Auristic, Mad Greek and Caoimhín like this.
  10. Gokul7373
    Honeycomb May 5, 2020
  11. AnimeshMiri and Gokul7373 like this.
  12. krish1113
    Cupcake May 5, 2020
    krish1113 , via OnePlus 6T , May 5, 2020 :
    After the update the gallery issue is solved settings is not opening properly it took 10 to 15 secs to open and in whatspp any video playing and closing video the audio is still coming 10 seconds
  13. doc_niru
    Donut May 5, 2020
  14. X1545479131591
    Cupcake May 5, 2020
  15. AnimeshMiri
    Froyo May 5, 2020
  16. Caomhin
    OnePlus 9 Series Expert Community Expert May 5, 2020
    Caomhin , via OnePlus 6T , May 5, 2020 :
    1st
    Try clear OnePlus Launcher App info Cache, then restart the phone.
    2nd
    If that doesn't work, try the following.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
  17. Darshan5015
    Froyo May 5, 2020
    g_castorina likes this.
  18. Artemus
    Didn't you learn from the previous updates? Calibrate the battery.
    Auristic, ironass and Caoimhín like this.
  19. Caomhin
    Post, just posted, above yours. All that info may help relieve the draining battery info.
    Auristic and Artemus like this.
  20. AmitExpectations
