249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. nnasit
    Cupcake May 9, 2020
  2. Caomhin
    Marshmallow May 9, 2020
    Caomhin , via OnePlus 6T , May 9, 2020 :
    nnasit
    yes​
    You will need to unbrick your phone.
    Follow the instructions to use the MSMDownload Tool for OnePlus 6T.
    https://www.thecustomdroid.com/oneplus-6-6t-unbrick-guide/
    Scroll down to view the Unbrick details and downloads.
    Download and use the Android version you want TO use to unbrick the phone with for OP6T.
    Once you have the phone backup and running.
    Install OTA updates to get the most recent update.
    You will lose all data on the phone as this will factory reset your phone.
    NOTE.
    If you install Android 9 from above guide. You must be on at least Android 9.0.17 in order to update to Android 10.
    You can then update to the Latest OOS full install file update
  3. Naveen Rayala
    Eclair May 9, 2020
    Naveen Rayala , via OnePlus 6T , May 9, 2020 :
    bro I installed latest launcher 4.4.2 but status bar looks same.could you guide me how to get.
  4. rhyd1am
    Jelly Bean May 9, 2020
    rhyd1am , via OnePlus 6T , May 9, 2020 :
    What were you expecting to change with the status bar?
    Auristic and Caomhin like this.
  5. aniketroyal
    Cupcake May 9, 2020
  6. Caomhin
    Should be there within the next 15 days, or you can manually install it. Posts throughout this thread have suggestions on how you do that.
  7. aniketroyal
    Cupcake May 9, 2020
    aniketroyal , May 9, 2020 :
    my security patch level was February .the April security patch level i get in june ?????
  8. rhyd1am
    These are the details you should have if you are on 10.3.3
    drl431 and Caomhin like this.
  9. RedGear007
    Cupcake May 9, 2020
  10. Naveen Rayala
    Eclair May 9, 2020
  11. aniketroyal
    Cupcake May 9, 2020
  12. Caomhin
    That's up to you, install manually or wait. Many have chosen the former option to update.
    Artemus. and rhyd1am like this.
  13. rhyd1am
    The OnePlus 8 status bar icons were not mentioned in the launcher update. What made you think they'd be included?
    kjjm, drl431, Auristic and 1 other person like this.
  14. Caomhin
    2 posts up from yours, there is even a conversation in posts above and below yours about it. 🙄🙄
  15. rhyd1am
    drl431, Auristic, ironass and 2 others like this.
  16. Rushi0099
    Cupcake May 9, 2020
  17. Artemus.
    Nougat May 9, 2020
    Artemus. , May 9, 2020 :
    When you learn to be patient and/or read the first post explaining the process.
    Caomhin, drl431, Auristic and 3 others like this.
  18. Rachit1608
    Cupcake May 9, 2020
  19. Auristic
    KitKat May 9, 2020
    Caomhin, Artemus. and ironass like this.
  20. Jayants2812
    Cupcake May 9, 2020
    Dipkesh likes this.
