250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. aakarshan.bhagat
    Eclair Apr 26, 2020
  2. rHITkM.
    Ice Cream Sandwich Apr 26, 2020
  3. rHITkM.
    rHITkM. , via OnePlus 6 , Apr 26, 2020 :
    check for the update on play store there is OnePlus launcher version 4.4.2 available. then check the phone app issue if it still persist after launcher update
    Caoimhín likes this.
  4. Krupesh3009
    Froyo Apr 26, 2020
    Krupesh3009 , via OnePlus 6T , Apr 26, 2020 :
    not available in playstore... still on 4.3.8
    rHITkM likes this.
  5. rHITkM.
  6. rHITkM.
  7. Krupesh3009
    Froyo Apr 26, 2020
  8. rHITkM.
  9. Jasmin0011
    Cupcake Apr 26, 2020
    Jasmin0011 , via OnePlus 6 , Apr 26, 2020 :
    I'm also having the same issue you have with op 6.
  10. Artemus.
    Community Hero 2020 Apr 26, 2020
    Artemus. , Apr 26, 2020 :
    Did you try factory resetting?
    Auristic, Caoimhín and Jasmin0011 like this.
  11. Jasmin0011
  12. Artemus.
    Are you sure you're doing a full wipe? Also, you don't have to do it every update, just major ones.
    Jasmin0011, Auristic and Caoimhín like this.
  13. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 26, 2020
    Caomhin , via OnePlus 6T , Apr 26, 2020 :
    That's where I install most OnePlus app updates from.
    Many of them never appear on Playstore. Do a check to ensure someone else has installed apps from there previously, they are perfectly safe, but compatibility can be the issue.
    OnePlus Launcher 4.4.2 is fine though on my OP6T.
  14. rHITkM.
    it is working good on my 6 too
  15. Z1553239049735
    Froyo Apr 27, 2020
  16. narceoneplus2
    Ice Cream Sandwich Apr 27, 2020
  17. VJM_21
    Gingerbread Apr 27, 2020
  18. Maverick2.0
    KitKat Apr 27, 2020
    Maverick2.0 , Apr 27, 2020 :
    Just to be 100% certain, once the full zip file is available, I can install it over OB 6 without loss of data , right?
  19. Shrinidhi_UI
    Eclair Apr 27, 2020
    Shrinidhi_UI , via OnePlus 6T , Apr 27, 2020 :
    Will upgrading from beta6 to 10.3.3 full installation file wipe all user data as similar to the downgrade case of beta to stable??
