250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. ShridharD
    Donut May 15, 2020
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 15, 2020
    Caomhin , via OnePlus 6T , May 15, 2020 :
    Check the posts I this thread, there are other manual ways to get it. You do have to be on a Stable 10 version before being offered OTA. Or possibly the last version of Stable Android 9
  3. Nasserq
    Cupcake May 15, 2020
    Nasserq , via OnePlus 6T , May 15, 2020 :
    battery life after update 10.3.3 very Disappointed before update screen on time was 6Hr after update 4Hr only !!!!!
    why [e]1f44e[/e]🏻[e]1f44e[/e]🏻[e]1f44e[/e]🏻[e]1f44e[/e]🏻
  4. Artemus.
    Community Hero 2020 May 15, 2020
    Artemus. , May 15, 2020 :
    Because you failed to calibrate the battery.
  5. Nasserq
  6. Artemus.
    Drain it to ~15%, charge it as long as possible (overnight is best) then repeat that process the next few days.
    Caoimhín and Auristic like this.
  7. Nasserq
    battery life before update was good i just updated before 2 days after that battery life go down. I think the problem due the update.
  8. Artemus.
    Nope, this happens literally every update and the solution is the same. The reason it was better before the update is because it was calibrated to your usage patterns. Essentially, you have to do it again.
  9. Nasserq
    I will try , thank you for your help i appreciate it.
    G_Dhanapal_mEPD and Artemus. like this.
  10. DS_chakri
    Froyo May 15, 2020
    DS_chakri , via OnePlus 6 , May 15, 2020 :
    Guys, a small help
    I already have realme buds wireless bluetooth headset.
    Should i go on and buy Oneplus bullets Z wireless.
    It is worth upgrading?? Pls advice.
  11. Artemus.
    That's completely up to you. How much was the "realme buds wireless bluetooth headset" and are you comfortable buying a new pair just to compare them?
    Caoimhín, Auristic and D Sai Chakri like this.
  12. DS_chakri
    Froyo May 15, 2020
    It was 1500 INR, yes i can afford new one but just want to know will the audio quality be good in oneplus z earphones.
    bcoz the wireless earphones from oneplus all of them till date lacked BASS . which i hated. so can i trust this time the improved BASS.?
  13. kulwinderjit
    Donut May 15, 2020
    kulwinderjit , via OnePlus 6 , May 15, 2020 :
    any detail on black screen while gaming bug fix? cod mobile said same in their latest fix but issue was still there. Now op says it is fixed so need to check if it is really fixed.
    D Sai Chakri likes this.
  14. viveksinhaxp
    Froyo May 15, 2020
    viveksinhaxp , via OnePlus 6T , May 15, 2020 :
    Guys one off topic question again..I am on 10.3.3 on my 6T but I am still on 1st March 2020 Google Play system update. if any has got 1st May 2020 Google Play system update,can you please provide me the process to update it. My Google Play Store version is 20.1.17 and Google Play Services version is 20.15.16
  15. DS_chakri
    Froyo May 15, 2020
    Yes, Seems to be fixed. yesterday i had played COD n PubG for 2 hours and sone other games as well. No issues encountered.
  16. Tee_Eee_Bee
    Ice Cream Sandwich May 15, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 15, 2020 :
    You should be able to tap on the Google Play store update in Settings -> Security & Lock Screen.
    If there is an update available, it should download and install.
  17. aadilwanicru
    aadilwanicru , May 15, 2020 :
    after updating my device i again started getting those white lines on the corners . was this update for a good purpose or just creating problems
  18. ajafov98
    ajafov98 , via OnePlus 6T , May 15, 2020 :
    Some of OnePlus apps deleted after this update (Weather, icon packs, Community and etc).
    I installed them and now I can't find widget shown in photo.
    What can I do? :/
  19. FaleshC
    KitKat May 15, 2020
    FaleshC , May 15, 2020 :
    its OnePlus widget.
    if not available, install from apkmirror.
    mayrsona, Artemus. and ajafov98 like this.
  20. ajafov98
