250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. sanjey sniper
    Gingerbread May 15, 2020
    sanjey sniper , via OnePlus 6T , May 15, 2020 :
    my mobile is in 10.3.0 update and I didn't update to 10.3.1 and 10.3.2 updates and I'm directly goin to update to 10.3.3.will the last two update packages carry with 10.3.3 update? or it will not!!
  2. viveksinhaxp
    Froyo May 15, 2020
    viveksinhaxp , via OnePlus 6T , May 15, 2020 :
    did already but still on 1st March 2020
  3. Auristic
    Lollipop May 15, 2020
    Auristic , May 15, 2020 :
    They will.
    Caoimhín, ironass and drl431 like this.
  4. SaravananRs
    Eclair May 15, 2020
    SaravananRs , via OnePlus 6 , May 15, 2020 :
    Still 5 Ghz bandwidth wifi issue not fixed .
    Frequent disconnection of wifi happens in 5 Ghz bandwidth
    Team after updating to android multiple release came not one release fixed this issue
  5. PrateekSinghania
    Eclair May 15, 2020
    PrateekSinghania , May 15, 2020 :
    are you sure it is not buggy? because many threads mentioned that it is buggy?
  6. ItsRavi25
    Jelly Bean May 15, 2020
    ItsRavi25 , via OnePlus 6T , May 15, 2020 :
    i tried in my oneplus 6 via oxygen updater..and i received via OTA in my oneplus 6T both are working same...great battery backup....and everything is working fine...
    I am also confused why some users are facing problems as we all are using same update.
    you should try it is totally same as OTA...
    Caoimhín and PrateekSinghania like this.
  7. Tee_Eee_Bee
    Ice Cream Sandwich May 15, 2020
    Tee_Eee_Bee , via OnePlus 6T , May 15, 2020 :
    Look in Settings -> Wi-Fi & Internet -> Wi-Fi -> Wi-Fi Preferences
    Make sure you have selected a 'Network rating provider's e.g. Google
    This may help, especially if you have selected 'Connect to open networks'
    Caoimhín and Auristic like this.
  8. SaravananRs
    Eclair May 15, 2020
    Network rating provider is selected as Google only.
    Still I face this issue ,I don't face any issue when I work with my laptop.
    Frequent disconnection happens only when I connect in 5ghz bandwidth
    Filip Randjak likes this.
  9. Trevor.Hawkes
    Trevor.Hawkes , May 15, 2020 :
    But many say it isn't buggy.
    You must read the threads and decide for yourself.
    I have 5 models 1,2,3,5,6 mostly updated many times. In all those updates I've had very few problems only. Others however have reported many problems and many had no problems at all.
    If you have problems someone here will try to help you.
  10. Auristic
    If you've already:
    - Disabled "Use random MAC address" in the Wi-Fi preferences on your SSID
    - Reaffected the new MAC address in your router's Wi-Fi whitelist (if you made one)
    - Disabled "Use private DNS" on your device
    It could be the right moment to think "What if it were my router's fault?" and try to solve the issue on the router's end asking yourself:
    - "Is 5Ghz covering correctly the room I'm in and (since 2.4 Ghz covers a broader distance than 5 Ghz)?"
    - "Is 2.4 Ghz better for me?"
    - "Is there a new firmware solving this type of issues for my router"...
    And all these questions you can ask yourself as far as you router is concerned.
    drl431, Caoimhín and ironass like this.
  11. MMohtady
    Cupcake May 15, 2020
    MMohtady , May 15, 2020 :
    since I have updated to this version the mobile is heating up, tried to restart but still mobile is still heating in simple use
  12. Auristic
  13. PrateekSinghania
    Eclair May 15, 2020
    thanks bro[e]1f481[/e]
  14. PrateekSinghania
    Eclair May 15, 2020
    thanks for the suggestion bro
  15. DS_chakri
    Froyo May 15, 2020
    G_Dhanapal_mEPD likes this.
  16. Caomhin
    OnePlus 9 Series Expert Community Expert May 15, 2020
    Caomhin , via OnePlus 6T , May 15, 2020 :
    The latest one is 4.4.4. 4.4.3 & 4.4.4 are Beta builds and the Beta is closed as they have enough participants
    You can download and install the latest version from ApkMirror
    Oneplus are usually behind with updates on the Playstore.
    ItsRavi25 and D Sai Chakri like this.
  17. DS_chakri
    Froyo May 15, 2020
    DS_chakri , via OnePlus 6 , May 15, 2020 :
    Thank You bro,
    Can you suggest best Gcam app.. for oneplus 6
    Caoimhín likes this.
  18. Anmol_2801
  19. vteccorp
    Froyo May 15, 2020
    vteccorp , May 15, 2020 :
    PlayStore now distributes version 4.4.4. All you have to do is join the BETA program. :)
  20. vteccorp
    Froyo May 15, 2020
    D Sai Chakri and Filip Randjak like this.
