249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Vivek Unni
    Gingerbread May 16, 2020
  2. Caomhin
    Marshmallow May 16, 2020
    Caomhin , via OnePlus 6T , May 16, 2020 :
    Just did a Google search for OnePlus Call Volume, there are many suggestions for a fix, however many come back to contacting OnePlus directly on the issue.
    https://www.google.com/search?q=low...KHTaECR0QpwV6BAgOEBE&biw=412&bih=805&dpr=2.63
    Contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    Artemus. likes this.
  3. adi1001
    Honeycomb May 16, 2020
    adi1001 , via OnePlus 6T , May 16, 2020 :
    i can call using jio vowifi and it is working but sometimes it get disconnected and switches back to volte but this same is happening with airtel aslo on pervious build.
    actually i m using airtel an jio bothe sim in my 6t.
    bithe are connected to vowifi calling bt sometimes it disconnects automatically and reconnects automatically.
    u can see in screenshot.
  4. G1589607408136
    Cupcake May 16, 2020
    Mukul_Anand. likes this.
  5. adi1001
  6. Caomhin
    Try Clearing the Clock App info Cache and App info Storage.
    Also clear OnePlus Launcher App info Cache
    Restart the phone and see if that helps.
    G1589607408136 likes this.
  7. Q1588679334503
  8. Shabara
  9. Vivek Unni
    Vivek Unni , via OnePlus 6T , May 16, 2020 :
    tried the basic issue procedure for this but still it is persisting.
    any solution
  10. Intekhab145
    Intekhab145 , via OnePlus 6 Amber Red , May 16, 2020 :
    I am on open beta on my OnePlus 6, was I not supposed to get the April security patch, which open beta users are supposed to get before the stable os users. My device running on open beta 35 is still running on March security patch but the stable devices have received the April security patch. I am not sure what OnePlus is planning for its open beta users. [e]1f613[/e]🙄🙄
  11. Sun90
    Starting Point Expert Community Expert May 16, 2020
    Sun90 , May 16, 2020 :
    AFAIK, the open beta program is over for the 6/6T.
  12. Intekhab145
    Sun90 likes this.
  13. FaleshC
    KitKat May 16, 2020
    FaleshC , May 16, 2020 :
    They are planning nothing as of now. They ended the Beta program last month. I guess you missed the news.
    No more Beta updates for Beta Channel.
    Shift to Stable channel if you want any future updates.
    mayrsona, LegolasX and Caomhin like this.
  14. Sun90
    ironass, Auristic and Intekhab145 like this.
  15. Caomhin
    Check my post 7 up from yours on how to optimize battery and phone. See if that helps
  16. Caomhin
    Remove all screen locks, Pin, Fingerprint, Facelocks etc
    Then remove all Smart Locks as well.
    Clear OnePlus Launcher App info Cache
    Restart the phone
    Setup the Fingerprint again, see if that helps.
    rhyd1am likes this.
  17. rhyd1am
    Jelly Bean May 16, 2020
    rhyd1am , via OnePlus 6T , May 16, 2020 :
    Security patches are included in the OS updates. The android 10 betas have finished. So the more recent release of 10.3.3, has the more recent security patch. If it use important to you then you'll have to move to stable 10.3.3 🤷‍♂️
    Auristic and Caomhin like this.
  18. Caomhin
    Unfortunately not, other than what has been suggested in those search links.
    Suggest contacting OnePlus support directly as I mentioned and see what they can do for you on that issue.
    rhyd1am likes this.
  19. O1589629337457
    O1589629337457 , May 16, 2020 :
    When will the - extremely annoying and frequent - frame drops be addressed? This is going on for months, and started with the Android 10 update. It happens especially when browsing through recent apps, open tabs in Chrome. And don't forget about the random crashes in browser when scrolling. I'm a big fan of OnePlus, but this is ridiculous.
  20. Farrukh Khan
