250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. I1534346194715
    Cupcake May 21, 2020
    I1534346194715 , via OnePlus 6 , May 21, 2020 :
    Thanks brother
    Will it automatically disappear ?
  2. drl431
    Community Hero 2020 May 21, 2020
    drl431 , May 21, 2020 :
    That list is cleared every time the phone is fully charged. Then a new list is started.
    Artemus and I1534346194715 like this.
  3. I1534346194715
    Thanks brother
    But is there is any battery draining issue in 10.3.3 update in OnePlus 6
  4. drl431
    My OP6 running 10.3.3 seems fine, but I'm sure we are not running the same apps. Are you saying that there was no battery issue with 10.3.2?
    Caoimhín, Auristic and Artemus like this.
  5. I1534346194715
    Yaa I have no battery issue with 10.3.2 I think I'm assuming more that battery is draining fast
    let's see after using more couple of day
    and thanks for sharing feedback
  6. drl431
    Yes, allow 3 or 4 full battery cycles after an update. Also charge the phone overnight, at least occasionally, to allow the system to calibrate for your battery usage.
    Caoimhín, I1534346194715 and Artemus like this.
  7. Z1578388055854
    Z1578388055854 , via OnePlus 6T , May 21, 2020 :
    There are some problems with this software update
    1. Move in function not working in gallery
    2. After using a app like chrome, you tube when i minimise them using home button, again apps were started from the home page.
    kindly resolve these bugs....
  8. avi0616
    Donut May 21, 2020
  9. D.Sai Suhail Baba
    Jelly Bean May 21, 2020
  10. drl431
    Turn off Hearing aid compatibility in the Accessibility menu. This setting is off by default.
    Artemus and Caoimhín like this.
  11. avi0616
    Donut May 21, 2020
    avi0616 , via OnePlus 6T , May 21, 2020 :
    thanks now its normal
    drl431 likes this.
  12. Avenger_Vinod
    Gingerbread May 21, 2020
  13. ItsRavi25
    ItsRavi25 , via OnePlus 6T , May 21, 2020 :
    Avenger_Vinod
    Did any one face any new issues with this update ?​
    Read the thread you will come to know what are the issue's that users are facing...
    For me i didn't find any major issue till now..
    This update is the best update..
    Smooth functioning and long battery backup..
    Artemus, Caoimhín and Avenger_Vinod like this.
  14. Ashish_07
    Ashish_07 , via OnePlus 6 , May 21, 2020 :
    I've updated to the latest update 10.3.3 but I'm still facing the black out screen problem, but not during the game whenever I make whatsapp calls and zoom calls my phone's screen gets black for couple of minutes and I'm helpless I cannot do anything till it's gets to normal. Why is it happening? is there a problem with the sensor?
  15. S Ashwin
    Froyo May 21, 2020
  16. aalsiBanda
    aalsiBanda , via OnePlus 6 , May 21, 2020 :
    Your battery is performing really good.
    Your device is consuming 7% in standby for 8-9 hrs.
    So, it will drain out in approximately 120-130 hours which is a really good standby.
    My OP6 gives only 70-80 hours of standby.
    If you don't want your device to suck up the battery juice overnight then you can switch it off or set an auto switch off and switch on from settings during night hours.
  17. R1543465200018
    Froyo May 21, 2020
    R1543465200018 , May 21, 2020 :
    Can I install OnePlus launcher 4.4.5 apk downloading from Google?? what could be the problem if I do it? launcher still not released in playstore so.
  18. rhyd1am
    KitKat May 21, 2020
    rhyd1am , via OnePlus 6T , May 21, 2020 :
    R1543465200018
    Can I install OnePlus launcher 4.4.5 apk downloading from Google?? what could be the problem if I do it? launcher still not released in playstore so.​
    What is your current version?
    You can install it from APK mirror, but just because you can, doesn't necessarily mean you should where system apps are concerned. Done it myself many times with no issues, but there are numerous people who have done so and caused themselves issues.
    In short, It won't necessarily do any harm, but if your device is currently working well, then there's really no need. Up to you 🤷‍♂️
    Caoimhín and Auristic like this.
  19. sam200794
    Donut May 21, 2020
    sam200794 , May 21, 2020 :
    I m facing a lot of problems in this new update. like:-
    1) Heating of the phone (Majorly)
    2) Hanging
    3) Auto Restart anytime.
    Please let me know what to do.
    matteo gioia likes this.
  20. matteo gioia
    Eclair May 21, 2020
    matteo gioia , May 21, 2020 :
    I am having the same issue as you and the other user on page 240 of the thread. I made a full wipe twice and cleared the cache after - it seems to fix the heating for now but my phone still randomly disconnects from the network. I also tried limiting network activity in background but don't know if it is helping.
