250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. J1535022703906
    Cupcake May 21, 2020
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 21, 2020
    Caomhin , via OnePlus 6T , May 21, 2020 :
    Reset your Bluetooth adapter, see if that helps
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
  3. Charan kumar Manthena
    Gingerbread May 21, 2020
  4. sateesh1248
    sateesh1248 , May 21, 2020 :
    After upgrade of 10.3.3 Dash charging not working, I'm frustrated with these One Plus upgrades. There will be a major bugs 2/3 for sure in each upgrade of One Plus.
    Dash charging is the main feature in One Plus, how come you people screwed up this ???
    I saw so many comments in community about this like clean the port it will work and closing issue as invalid. How come it's a port issue ?? why can't you understand we are facing this issue after upgrade of 10.3.3.
  5. rhyd1am
    KitKat May 21, 2020
    rhyd1am , via OnePlus 6T , May 21, 2020 :
    No...... YOU are facing this issue. My device (and the majority of others) are charging perfectly well. I'm not trying to say you don't have an issue, but it is far more likely to be an issue with your charger, cable or charging ports, than it is an issue from the update (otherwise we'd all be experiencing it) 🤷‍♂️
    Auristic, kjjm, Caoimhín and 2 others like this.
  6. Artemus
    Community Hero 2020 May 21, 2020
    Artemus , May 21, 2020 :
    Because normally it's a port issue. Debris and dust can accumulate in the grooves of the Type-C port and prevent contact from being made between the circuits. Usually if you have this issue, cleaning the ports is the way to go.
  7. W1590078570100
    W1590078570100 , May 21, 2020 :
    Any one experiencing audio issues while making receiving calls after the 10.3.3 upgrade? the sound is really faint at my end even while on speaker phone. However, the audio/sound works well and is at full volume when I make a whatsapp call. So basically not a phone issue rather a software issue. @OnePlus pls look into this
  8. Artemus
    That user isn't associated with OP, just FYI. Tagging them won't do a thing.
  9. sateesh1248
    Then why not same problem is there in previous version of 10.3.2 ?? why suddenly occur after upgrade of 10.3.3 ..?
  10. sateesh1248
    Then why not same problem is there in previous version of 10.3.2 ?? why after suddenly occur after upgrade of 10.3.3 ..?
  11. Artemus
    I've never had this issue in either update. Trust me, just do a quick check of the port and see if there's any dust or debris in the port. If there is, use a toothpick or non-conductive brush to get it out. It takes literally 5 seconds.
  12. W1590078570100
    What's the correct user name if you may know..
  13. rhyd1am
    KitKat May 21, 2020
    Auristic and Caoimhín like this.
  14. Artemus
    None. Developers don't read this forum. If you want to submit feedback, use the official feedback section @ https://forums.oneplus.com/feedback (or if using the Community app, the same red button used to make a new thread but hit "Feedback" instead).
  15. I1590076586326
  16. W1590078570100
  17. Caomhin
    If it was common problem, it would be on this thread every minute every hour. Out of Millions of 6 series phones, there are a few with issue you experience. It seems that Android 10 is a little more sensitive to connections made.
    In most cases, cleaning the Ports on the Phone, Charger and both ends of the Cable tend to fix the issue.
    In a minor few cases, where cleaning does not fix it, chances are, that because Android 10 is set to be more sensitive to those connections, its possible that it is identifying a minor issue within a port connection, whether that be the phone, charger or cable connectors and ports.
    Contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  18. T1583928913408
    T1583928913408 , May 21, 2020 :
    In Oxygen OS 10.3.3 the battery optimization is not good as it was on Oxygen OS 10.3.2, kindly look forward to optimize battery usage in further Oxygen OS updates. As I am using OnePlus 6, and found the issue within a day. Thanks you OnePlus community, and keep it up as always [e]1f44d[/e][e]1f44d[/e]. I am a big fan of Oneplus Devices.
  19. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    drl431 likes this.
  20. U1533484940620
    U1533484940620 , May 21, 2020 :
    i have OnePlus 6T McLaren version... I'm facing the same issue... Warp charging and my headphones are not working.
