250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. K1530559386745
    Cupcake May 21, 2020
    K1530559386745 , May 21, 2020 :
    Hi,
    After update im facing Internet connection problem. disconnecting inbetween and when we are playing game display going to dark mood. no use this update.
  2. D1564682546547
    D1564682546547 , May 21, 2020 :
    I have updated to this version but I didn't get call recording option in my phone. what I need to do to get that option.
  3. matteo gioia
    Eclair May 21, 2020
    matteo gioia , May 21, 2020 :
    As many users continue to report network issues and overheating I made a bug report on the official forum.
    I confirm my SIM is not shorting, as it perfectly works in other devices. Also not having the sim inside seems to fix the network issue (wifi is fine).
    If other users that are facing the same issue could discuss there it would be great.
  4. A1561186094112
    A1561186094112 , May 21, 2020 :
    Hi Team,
    My phone ringtone suddenly changed to beep sound. where should I report this in current covid situation.
    thanks and regards
    Omkar Kulkarni
  5. matteo gioia
    Eclair May 21, 2020
    Explain better please. You mean it's just beeping when they call you?
  6. Auristic
    Lollipop May 21, 2020
    Auristic , via OnePlus 6T , May 21, 2020 :
    Where do you come from?
    Is it legal in your country?
    mischa1981, ironass and Caoimhín like this.
  7. Caomhin
    OnePlus 9 Series Expert Community Expert May 21, 2020
    Caomhin , via OnePlus 6T , May 21, 2020 :
    Same possible solution on cleaning the ports, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden toothpick carefully.
    Bluetooth Headphones issue. Reset the Bluetooth on the phone.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    If they are connected via wired headphone adapter to USB C, again clean the ports.
    ironass likes this.
  8. Caomhin
    Reset your WiFi adapter.
    drl431 likes this.
  9. D1564682546547
    what you are talking about ?
  10. Auristic
    Phone recording is only available on OP devices in countries where this is legal hence my question.
    I didn't ask you what you needed that for because this is none of my business but note I find that useless unless you have unlawful puposes.
  11. C1542526158633
    Eclair May 22, 2020
    V1528784383877 likes this.
  12. J1535022703906
    Cupcake May 22, 2020
    J1535022703906 , via OnePlus 6 , May 22, 2020 :
    still facing same problem
  13. Artemus
    Community Hero 2020 May 22, 2020
    Artemus , May 22, 2020 :
    When did you last wipe your phone? And I don't mean cache.
    C1542526158633 and Caoimhín like this.
  14. sam200794
    Donut May 22, 2020
    sam200794 , May 22, 2020 :
    done a full reset of the phone.
    still the heating issue isn't resolved..
    instead the heating of the phone increased to a level that I m not able to hold my phone for more than 5mins. it's that hot.
  15. Artemus
    How hot is your area right now? (Use AccuWeather)
    Caoimhín likes this.
  16. sam200794
    Donut May 22, 2020
    34°C
  17. Artemus
    There's your problem. Hot-as-hell outside, hot-as-hell phone. Simple science.
    drl431 and Caoimhín like this.
  18. sam200794
    Donut May 22, 2020
    Last year I was in some other place where it was much hotter. still the phone never showed the heating effect??
    the usage of the phone was also much higher than now.
  19. Artemus
    Download CPU-Z from the Play Store and screenshot the thermals. Normal operating temperatures range between 30-40°C, 45 and higher means the SOC is being used more.
  20. V1528784383877
    Eclair May 22, 2020
