250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. R1543465200018
    Froyo May 22, 2020
    R1543465200018 , May 22, 2020 :
    I'm seeing lot of UI frame drops in this update. Been observing 3-4 times in a day. it's very annoying to see scrolling. I cleared cache and did format also.
    any body else facing this problem.
  2. amalwajid
    Eclair May 22, 2020
    amalwajid , via OnePlus 6T , May 22, 2020 :
    please optimize camera with improvement . nowadays camera selfies gone not clearly output . sometimes blurring not shaked my hand . please do something
  3. Caomhin
    OnePlus 9 Series Expert Community Expert May 22, 2020
    Caomhin , via OnePlus 6T , May 22, 2020 :
    Try it with a GCam and see if the same issue occurs.
    Dev Marco Gcam integrated XML files for 6 series phones.
    I have this one installed and it works very well.
    7.3_GCam_MJL_v4.1.1_Minilux.apk (marco, 2020-04-29, oneplus 6/6t, changelog)
    The XML are integrated, so no additional files required.
    https://www.celsoazevedo.com/files/android/google-camera/dev-marco/
    rhyd1am, ironass and Auristic like this.
  4. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    drl431 and rhyd1am like this.
  5. Caomhin
    Try the steps in the post #4917 above this post see if it helps.
  6. amalwajid
    Eclair May 22, 2020
  7. Caomhin
    Not sure what you mean by that, what I was suggesting, was to try the Gcam software to take pictures and compare them to one's taken on stock. And see if you can see any difference. As in, is there any improvement.
    I use the Gcam all the time now.
    Auristic likes this.
  8. L1585639905340
    Cupcake May 22, 2020
  9. Auristic
    Lollipop May 22, 2020
  10. D.Sai Suhail Baba
    Jelly Bean May 22, 2020
    D.Sai Suhail Baba , May 22, 2020 :
    L1585639905340
    after this update my battery is draining in night! fix the bug​
    Complain your issues to OnePlus through feedback. OnePlus customer service will reply.
    L1585639905340 likes this.
  11. sam200794
    Donut May 22, 2020
    sam200794 , May 22, 2020 :
    Done the full factory reset again and installed all the apps from playstore. didn't took any backup.
    still facing the heating issue.
    Update created mess likes this.
  12. matteo gioia
    Eclair May 22, 2020
    matteo gioia , May 22, 2020 :
    what worked for me was full wipe, full wipe, cache wipe
    Caoimhín likes this.
  13. Vyshak Balagopal
  14. sam200794
    Donut May 22, 2020
    but it's not working for me
  15. matteo gioia
    Eclair May 22, 2020
    It didn't work for me to after the first wipe. I had to wipe twice and then wipe the cache again and only after that the issue mitigated.
    I'll do a general update on my whole bug situation later
  16. sam200794
    Donut May 22, 2020
    how to clear only the cache again??
  17. Caomhin
    Just to check, when doing the wipe, do you enable Erase Internal Storage, image below, before clicking Delete All Data?
  18. Caomhin
    Many say this does nothing as the Cache partition was removed with the new Android partitions.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    ironass likes this.
  19. sam200794
    Donut May 22, 2020
    yes I erased all the internal storage as well both the times.
  20. Caomhin
    Let us know if you have any success with the cache wipe as mentioned above.
