250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Maverick2.0
    KitKat May 22, 2020
    Maverick2.0 , May 22, 2020 :
    OMG! You are genius! :)
    ironass and Caoimhín like this.
  2. S1558615625632
    Eclair May 22, 2020
    S1558615625632 , via OnePlus 6T , May 22, 2020 :
    hi all guys,recently I updated to my OnePlus 6t to 10.3.3.i my phone battery gets draining faster as compared to as 10.3.2 update,OnePlus team kindly fix this issue through upcoming updates.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert May 22, 2020
    Caomhin , via OnePlus 6T , May 22, 2020 :
    Wouldn't say that now, this is quite a common possible fix that is easily found in Settings. At least some can find it, others maybe not.
    So did it fix the issue?
    Maverick2.0 likes this.
  4. Maverick2.0
    KitKat May 22, 2020
    Of course it did! Why do you think I called you a genius ? 😁 ;)
    As for it being a common fix, this one isn't very common. I knew it myself tbh,but had completely forgotten about it. It's kind of hidden,you know.
    rhyd1am and Caoimhín like this.
  5. O1590155236831
    Cupcake May 22, 2020
    O1590155236831 , May 22, 2020 :
    After the latest update of 10.3.3 with Android security patch level of April 2020. After the update the battery backup is quite irrevalant of what my device was capable of in the oldest version.....In the previous version I was capable of playing 3-3.5 hours pubg ...but after the update my battery is draining very fast and I m only getting hardly 2 hours backup....plzz help me if any 1+6 user are also facing same issue
  6. Caomhin
    Glad to hear you got sorted, happy days. 🙂[e]1f44d[/e]
    ironass and Maverick2.0 like this.
  7. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
  8. Funk Wizard
    Moderator Moderator May 22, 2020
    Funk Wizard , May 22, 2020 :
    Please discuss the same on the release thread, Merged
    Caoimhín and S1558615625632 like this.
  9. Trevor.Hawkes
    Ice Cream Sandwich May 22, 2020
    Trevor.Hawkes , May 22, 2020 :
    I agree but a restart is a good first step to getting simple things sorted out.
    Caoimhín likes this.
  10. Vikashlb
    Honeycomb May 22, 2020
    frshboxx likes this.
  11. matteo gioia
    Eclair May 22, 2020
    matteo gioia , May 22, 2020 :
    Phone randomly heated during charge at 55% and rebooted after losing all network signals. After removing SIM, it went till 100% perfectly fine (all the rest of the charging was done with no SIM).
    Now I'm using it unplugged with the SIM inside again and it seems to be working fine. I'll report tonight/tomorrow if (as it did before) will work just fine.
    So so far the only "fix" to the signal/overheating mix is:
    1) Wipe data and cache twice
    2) Wipe cache (just to be sure)
    3) Reset network adapter
    4) Avoid to use previous back ups (I don't know, I did use my drive backup for a few things but the apps where manually downloaded)
    5) Charge phone without SIM inside
    5 - optional) Use phone without SIM (I don't know, I need to do further testing)
    The combo that seems to bring to overheating is: charging, SIM inside, wifi either on or off.
    Vic8808 and Caoimhín like this.
  12. K1541433081803
  13. matteo gioia
    Eclair May 22, 2020
    There is nothing we can do. You can try to download it with Oxygen OS updater or from One Plus site
  14. Caomhin
    What build version are you currently on.
  15. Ehtk
    Ehtk , May 22, 2020 :
    thx you so much! almost hard resetting!!
  16. Gokul7373
  17. Caomhin
    Same. Nothing to worry about. Have seen different builds vary between 10GB and 15GB
  18. Gokul7373
    Artemus. and Caoimhín like this.
  19. L1534147962120
    L1534147962120 , May 22, 2020 :
    hello sir,
    Since after the phone got updated to version 10.3.3, my phone is not working properly. the problems mentioned below:
    1. The Volume of the phone gets high and low automatically without pressing any keys.
    2. The songs starts playing even if the Songs application is closed/ exited.
    3. The Google voice assistant starts automatically.
    4. The wired earphones when plugged-in won't work properly.
    5. I have called to customer support and they have suggested to reset the app preferrences, which was done but it gave me no use as the same problem was repeated.
    Can you please look into the issue and get a solution on the same.
  20. frshboxx
    Gingerbread May 22, 2020
