248
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Funk Wizard
    Lollipop Moderator May 22, 2020
    Funk Wizard , May 22, 2020 :
    Continue discussion on the release thread
    Caomhin, Harman_Randhawa and Artemus. like this.
  2. sam200794
    Donut May 22, 2020
    sam200794 , May 22, 2020 :
    now again the heating issue is coming.
    the phone has started to heat.
    the temperature I checked on CPU Z is in the range 42-45°C now.
    what should I do.
    please provide a permanent solution for this.
  3. sam200794
    Donut May 22, 2020
    what should I do.
  4. Artemus.
    Nougat May 22, 2020
    Artemus. , May 22, 2020 :
    Did you try the formatting solution?
    Caomhin likes this.
  5. Caomhin
    Lollipop May 22, 2020
    Caomhin , via OnePlus 6T , May 22, 2020 :
    If OP support can't locate the issue, the only solution I could suggest, would be to Factory Reset.
    Do a full Erase/Delete All Data factory reset.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
  6. Caomhin
    You have pretty much done everything, only a couple of other suggestion I can give is to see if battery optimisation can help. It does take a couple of full charge cycles. Still no guarantee it will work.
    I will put this in 2 posts.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
  7. Caomhin
    2nd option, try a downgrade to a version you know worked fine.
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    Always BACKUP your phone before doing this as it will wipe the phone.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    ironass and frshboxx like this.
  8. Reetej Kumar khadka
    Gingerbread May 22, 2020
  9. Caomhin
    That's large, sometimes a full factory reset might reclaim some of that storage, but maybe only 3GB to 5 GB. Most cases it's not really worth it.
  10. matteo gioia
    Eclair May 22, 2020
    matteo gioia , May 22, 2020 :
    Ok reporting after full charge: 1h after using the SIM the phone lost signal multiple times, got really hot and rebooted. After reboot everything went good, I'm still using it and monitoring the situation.
    I know the SIM isn't shorting and at this point the only "fix" is just waiting for the first reboot. Maybe it has to do with some settings inside, but at least the devs claim they are tackling the issue so we have just to wait.
  11. Caomhin
    And also can't discount a possible hardware fault, if all other avenues have been explored.
    matteo gioia likes this.
  12. Xcutioner
    Honeycomb May 23, 2020
    Xcutioner , via OnePlus 6 , May 23, 2020 :
    Am I the only one who is impatient for Android 10 status bar icons like OOS 10.5 ... one of the few things I disliked about OOS 10 was that they decided to keep the Nougat style ones... Glad they changed their mind for OOS 10.5... but sad they made it exclusive just for Oneplus 8 series
  13. avinash@10
    Gingerbread May 23, 2020
  14. D1564682546547
    Cupcake May 23, 2020
    D1564682546547 , May 23, 2020 :
    it is legal in my country , actually one of my using this same phone he has recording option but haven't
  15. G_Amit_Tiwari_zcOu
  16. Smitamishra2203
  17. Artemus.
    Nougat May 23, 2020
    Caomhin likes this.
  18. Smitamishra2203
  19. Artemus.
    Nougat May 23, 2020
    Artemus. , May 23, 2020 :
    Mmm... did you click the link? It'll tell you they've been having a lot of problems as of late.
    Caomhin likes this.
  20. Smitamishra2203
    Smitamishra2203 , via OnePlus 6 , May 23, 2020 :
    Yes.But already same problem with OnePlus. Already in forum it's there.still not fixing issue.
