Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
Charging, battery, performance, caches and battery calibration myths busted
https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
After Backing up the phone.
Go to Settings,
System,
Reset Options,
https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
And here
https://www.androidauthority.com/best-android-backup-apps-and-other-ways-too-608014/Click to expand...
