250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Update created mess
    Cupcake May 26, 2020
    Update created mess , May 26, 2020 :
    This update is the worst ever update. It is seriously heating up the phone and draining the battery. Feels like a blast might happen of it continues to heat up. The weather of the city and temperature of my phone is same after this shitty update. Screw you one plus.
    WORST UPDATE 10.3.3:mad:
    Promil Kumar likes this.
  2. Update created mess
  3. Caomhin
    OnePlus 9 Series Expert Community Expert May 26, 2020
    Caomhin , via OnePlus 6T , May 26, 2020 :
    If you are in a hot climate such as 30° or higher, The air temperature at your location can cause the phone to heat while in use or charging. 6 series phones have no active cooling.
    However try the steps below to see if you can relieve some of the issue.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    rhyd1am likes this.
  4. Update created mess
  5. Caomhin
    As I mentioned, few suggestions to try as in my post above.
    Update created mess likes this.
  6. Update created mess
  7. Atmik123
    Eclair May 26, 2020
    Atmik123 , via OnePlus 6 , May 26, 2020 :
    Yes I just tried, but it didn't open than to. I think with new update they will fix the issue.
    Caomhin likes this.
  8. Update created mess
    Trying it . Will let you know if it works.
    Caomhin likes this.
  9. Update created mess
    I deleted all data yesterday still heating up my device
    Caomhin likes this.
  10. Caomhin
    Try the optimization options in the post above
    ItsRavi25 likes this.
  11. Yan_wImC
  12. FaleshC
    KitKat May 26, 2020
    FaleshC , May 26, 2020 :
    that was a open beta feature not pushed on Stable release.
    LegolasX and Caomhin like this.
  13. Advait Bhobe
  14. FaleshC
    KitKat May 26, 2020
    it doesn't?
    mine works fine in OnePlus 6 with my mask on.
    mayrsona and LegolasX like this.
  15. Advait Bhobe
  16. Prasad1183
    Caomhin likes this.
  17. Vivek Unni
    Gingerbread May 26, 2020
    Vivek Unni , via OnePlus 6T , May 26, 2020 :
    are you suggesting that this device should just magically convert it's camera to an iris scanner or something?
  18. Vivek Unni
    i am getting an issue with charging... past few days i have observed that the device is not charging fastly and sometimes it automatically switches to normal charging speeds..
    also observed that when the device is heated up pretty high then shows a message that "plugged in unable to charged your device right now"
    can someone explain this please?
  19. Caomhin
    Have you tried cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden toothpick carefully. To see if it an help.
    Also check that there are no bends or folds in the Cable and that the charger is not to hot to the touch.
  20. 09sailesh
