250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. Rocky065
    Eclair May 27, 2020
  2. Sukorno
    Cupcake May 27, 2020
    Sukorno , via OnePlus 6T , May 27, 2020 :
    after updating oxygenos 10.3.3 messenger video calls gets hang while i am switch off the screen power button. And sometimes still black screen appears when i open the game.
  3. Vikashlb
    Gingerbread May 27, 2020
  4. Artemus.
    Community Hero 2020 May 27, 2020
    Artemus. , May 27, 2020 :
    Lemme guess, PUBG?
  5. Vikashlb
  6. Artemus.
    Nope, I don't play games on my phone. How I guessed is, this is a common occurrence and the answer is the same: PUBG is horribly-optimized and has been for a long time. Doesn't matter what settings you play on, your battery will suffer all the same.
    drl431, Auristic and Caomhin like this.
  7. Vikashlb
    Vikashlb , via OnePlus 6T , May 27, 2020 :
    ohk thx
    Artemus. likes this.
  8. H1590558593678
  9. ItsRavi25
    Ice Cream Sandwich May 27, 2020
    ItsRavi25 , via OnePlus 6T , May 27, 2020 :
    Fix is here and its simple follow the steps below,
    This issue is due to the phone setting and its not a bug ,you need to enable to voice setting to fix this issue.
    (WIRED EARPHONE)
    Follow the below steps to fix this issue,
    1. Go to settings
    2.Select "Language and input" >> Google Voice Typing
    3.Now you will see option called "Hands-free" , select "Hands-free" and enable option called "for wired headset"
    (BLUETOOTH EARPHONE)
    1.Launch an inbuilt audio recorder to test microphone functionalities quickly.
    2.You can determine the quality based on the audio delay and shutters. Assuming the delay occurred then the wireless headphone microphone is not good enough to send & receive audio wave’s real-time.
    3.The recording comes out sharp & crystal clear, and then you may have discovered an internal bug.
    OR
    Get into OnePlus Android safe mode and test the functions for software failure.
    This will fix your issue of earphone. Enjoy using earphone :)
    manasarora98, Auristic and Caomhin like this.
  10. H1590558593678
    H1590558593678 , May 27, 2020 :
    Thanks..but the problem is still there..
  11. ItsRavi25
  12. H1590558593678
  13. ItsRavi25
    Clean your port and try to reconnect.
    If you're using type c earphone then try to use another one..if still didn't work that means there is Hardware issue...
    If you're using type c to 3.5 mm converter then there might be issue in converter....
    if still didn't work back to previous version..
    Because it's not a software issue.and 10.3.3 is most stable update till now.....only you're facing this problem
    Auristic and Artemus. like this.
  14. H1590558593678
    ok..but I can listen music, media..the issue occurs only on call, and I m able to hear other person's voice while the other person is unable to hear my voice..
  15. ItsRavi25
    [e]1f602[/e]
    Then there is problem in your earphone...
  16. H1590558593678
    thanks..but I have tried 2 other earphones also..
  17. N1541281596911
  18. Caomhin
  19. VenkateshCh
    Donut May 27, 2020
    Caomhin likes this.
  20. B_Wrath
    Nougat May 27, 2020
