250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. K1541433081803
    Cupcake May 27, 2020
  2. rhyd1am
    KitKat May 27, 2020
    rhyd1am , via OnePlus 6T , May 27, 2020 :
    You are already on 10.3.3 which was released 1 month ago. Not 2 months ago!
    What issue are you talking about? 10.3.4 had only been released today.
    It's a staged, random rollout. It goes first to a smaller group of "random" users, before going out to increasingly larger groups of users, and can take a couple of weeks to reach everyone.
    It's done this way to try to minimise the chance of any major bugs getting out there. Be patient and it'll soon reach your device 🙂
    Caoimhín likes this.
  3. Benjamin Leo
    Froyo May 27, 2020
    Benjamin Leo , via OnePlus 6 , May 27, 2020 :
    After updating my device to 10.3.3 I only encountered lag just one time when browsing queued YouTube video's. on 10.3.2 and prior it was a lot more common.
    after updating to 10.3.3 I've wiped cached data as well...
    in my case it's much much better now. hope this helps you too
  4. K1541433081803
    K1541433081803 , via OnePlus 6T , May 27, 2020 :
    I formet my then only that works one time I update playstore was not working. next any app automatically close. it was freeze also like black screen also . please help me
  5. K1541433081803
  6. alryder
    Gingerbread May 27, 2020
    alryder , May 27, 2020 :
    There is not a 5G radio in the OnePlus 6/6T. It is impossible for them to support 5G
    Artemus. and rhyd1am like this.
  7. manasarora98
    Ice Cream Sandwich May 28, 2020
    manasarora98 , via OnePlus 6 , May 28, 2020 :
    Well, I just switched to stable channel right now on 10.3.3 on OnePlus 6,
    Happy to say:
    1. OnePlus Roaming is there.
    2. Smart SMS is also there (I guess not sure)
    I had backed up data using OnePlus Switch, so in my messages, it does show categories in messages i.e. Transactional, OTP, Promotional.
    Dual Channel Acceleration is missing.
    Privacy Alerts added in OB4 are missing.
    Waiting for a wider rollout of 10.3.4 for Work Life Balance mode.
    Handling Theme notification is still there.
  8. Mohammad_Rizwaan
    Cupcake May 28, 2020
  9. Caomhin
    OnePlus 9 Series Expert Community Expert May 28, 2020
    Caomhin , via OnePlus 6T , May 28, 2020 :
    You can minimise the app notifications, and possibly silence any sound it makes.
    Go to Settings>Apps and notifications>All x apps>3 dot menu>Show system apps>Android System>Notifications|>FG OPThemes...
    Select Other less important without sound and Vibration.
    Should reduce intrusions.
    Artemus. likes this.
  10. manasarora98
    Yeah offcourse that was the first thing I did after switching to stable.
    Numerous apps were going to be installed and updated, it will start buzzing so had to do it.
  11. matteo gioia
    Eclair May 28, 2020
  12. K1541433081803
    Cupcake May 29, 2020
    K1541433081803 , via OnePlus 6T , May 29, 2020 :
    small think directly is not updating .I should go to google go to website OnePlus.com and OnePlus 6t and download it and next zipfile I should go local upgrade then download .this how I update it know. why OnePlus 6t is not giving notification for update new version . I feel this problem this cure as possible.oneplus 6t people can do everything.
  13. Caomhin
    OnePlus 9 Series Expert Community Expert May 29, 2020
    Caomhin , via OnePlus 6T , May 29, 2020 :
    They will, but don't post a new version such as 10.3.4 until it has been fully rolled out through their Random Staged Rollout procedure.
  14. nagarjuna003
    Gingerbread May 29, 2020
  15. Artemus.
    Community Hero 2020 May 29, 2020
    Artemus. , May 29, 2020 :
    What'd you try exactly?
  16. Artemus.
    Community Hero 2020 May 30, 2020
    Artemus. , May 30, 2020 :
    Why not 10.3.4?
  17. rhyd1am
    KitKat May 30, 2020
    rhyd1am , via OnePlus 6T , May 30, 2020 :
    You can't simply download 10.3.3, and install it over 10.3.4. You need to use the rollback to downgrade.
    Caoimhín and Artemus. like this.
  18. Caomhin
    OnePlus 9 Series Expert Community Expert May 30, 2020
    Caomhin , via OnePlus 6T , May 30, 2020 :
    ROLL-BACK FROM CURRENT ANDROID 10 Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    If you can, you could try a Full Factory Reset to fix the issue. Steps below to Factory Reset the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Your phone will now restart and go through the Full reset cycle.
    And its always good practice to backup phone data before upgrading.
    rhyd1am and Artemus. like this.
