250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. rhyd1am
    KitKat Jun 3, 2020
    rhyd1am , via OnePlus 6T , Jun 3, 2020 :
    All the links given in that thread are genuine and perfectly safe. Many users (myself included) have used them plenty of times before.
    Caoimhín and Artemus. like this.
  2. Artemus.
    Community Hero 2020 Jun 3, 2020
    Artemus. , Jun 3, 2020 :
    It's genuine. You can't downgrade by conventional means, you have to use a specific downgrade build which will wipe your phone.
    Caoimhín and rhyd1am like this.
  3. Rajkumar_Pallerla , via OnePlus 6T , Jun 3, 2020 :
    there are many links what should i select
  4. Artemus.
  5. rhyd1am
    KitKat Jun 3, 2020
    Do it step by step.
    First click on the first link in the rollback thread I gave you (that will take you to XDA). When there click the correct rollback package for your device (either 6t or 6), and install it as per the instructions. You'll then be on android 9.
    Then return to the rollback thread I gave you, and download the latest stable android 9 version for your device (links are provided) which will either be 9.0.9 for the 6, or 9.0.17 for the 6t. Install that the same way.
    After you have that installed, you'll then be able to upgrade to 10.3.3 in exactly the same way (via local upgrade).
    Artemus. and Caoimhín like this.
  6. Rajkumar_Pallerla , via OnePlus 6T , Jun 4, 2020 :
    it is showing like this
  7. Tee_Eee_Bee
    Ice Cream Sandwich Jun 4, 2020
    Caoimhín likes this.
  8. rhyd1am
    KitKat Jun 4, 2020
  9. rhyd1am
    KitKat Jun 4, 2020
    rhyd1am , via OnePlus 6T , Jun 4, 2020 :
    Open it in your chrome browser. Links don't always work in the community app.
  10. Rajkumar_Pallerla , via OnePlus 6T , Jun 4, 2020 :
    i downloaded it and pasted in the root directory of internal storage but it is not given access to downgrade in system updates local upgrade option
  11. rhyd1am
    KitKat Jun 4, 2020
    Sorry, I should have mentioned in my previous post. You may have to edit the file name in file manager first.
    Check to see what the file ends with. If it ends with .jar then you need to delete the .jar
    After doing that, provided it's pasted correctly in the root directory, it should show up under local upgrade.
  12. Rajkumar_Pallerla
    Donut Jun 4, 2020
    Rajkumar_Pallerla , Jun 4, 2020 :
    Thanks a lot successfully rolled back to 10.3.3[e]1f64f[/e][e]1f64f[/e][e]1f64f[/e]
    rhyd1am likes this.
  13. H1557817058281
    Eclair Jun 4, 2020
    H1557817058281 , via OnePlus 6T , Jun 4, 2020 :
    Again my phone has started lagging .
    At first all bugs were fixed but since yesterday my phone is lagging a lot. While clearing the recent apps a black screen appears. I try to record this via screen recording but as soon as I switch it on and record the lagging stops and when I stop recording it starts lagging again.
    It's a humble request please help[e]1f64f[/e][e]1f64f[/e][e]1f64f[/e][e]1f64f[/e][e]1f64f[/e]
  14. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 4, 2020
    Caomhin , via OnePlus 6T , Jun 4, 2020 :
    Make sure you have the latest launcher installed from the Playstore.
    Clear the OnePlus Launcher App info Cache.
    Reboot the phone.
    See if that helps.
    Artemus. and H1557817058281 like this.
  15. H1557817058281
    Eclair Jun 4, 2020
    okay I'll try it
    thanks
  16. rhyd1am
    KitKat Jun 4, 2020
    No problem, glad it's sorted [e]1f44d[/e]
