250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. rockpizzulo
    Eclair Apr 27, 2020
    rockpizzulo , via OnePlus 6T , Apr 27, 2020 :
    It isn't a problem with the play store... Your phone can't access its memory in fact if you go on your gallery you find out that it's empty. I had the same problems while installing the 10.3.2 version and I solved it updating my system to the beta 6
    DeadEyeP likes this.
  2. DeadEyeP likes this.
  3. Federico Martin
    Gingerbread Apr 27, 2020
    Federico Martin , Apr 27, 2020 :
    So the solution is revert to Beta6 or Wipe the phone complete?
  4. DeadEyeP
    Froyo Apr 27, 2020
    DeadEyeP , via OnePlus 6 , Apr 27, 2020 :
    You can't revert to an earlier security version.
  5. Lupastro82
    Lupastro82 , Apr 27, 2020 :
    This bug is so strange!!
    Via file manager I see all to 0, via Files I can browser in my files. Via default gallery I see 0images, via whatapp or files images are present in dcim folder. Also, I can't make a screenshot (cannot save in memory). So, is a memory issue but atm a cannot fount any way to fix.
  6. ____Dpk____
    suraj1595 likes this.
  7. B_Wrath
    Nougat Apr 27, 2020
    B_Wrath , Apr 27, 2020 :
    Directly installed 10.3.3 over beta 6?
  8. Yannis Neris
    Ice Cream Sandwich Apr 27, 2020
  9. prkoparkar
    Froyo Apr 27, 2020
    prkoparkar , via OnePlus 6 , Apr 27, 2020 :
    use incremental update from oxygen updater. it is less than 300mb
  10. Federico Martin
    You are Right so a full wipe will solve? It's the only option?
  11. Archit@123
    Honeycomb Apr 27, 2020
    Archit@123 , via OnePlus 6T , Apr 27, 2020 :
    I have faced the downloading issue when once when I update from pie to open beta 1 andriod 10 without factory reset you can wait for some time mine got automatically fixed after 1 hr looks like apps are updating in background which caused the issue or you can go for factory reset which should fix the issue and is recommended for smooth transition.
  12. DeadEyeP
    Froyo Apr 27, 2020
    I'll hold fire to see what others find
  13. rockpizzulo
    Eclair Apr 27, 2020
    I don't know to be honest, but to rollback your phone to the beta you also have to wipe it...
    I think it's not the best idea if you don't have a backup because you also can't connect the phone to a pc...
    My advice is to wait for a newer update, in my case it worked and also I found in my gallery the photos/screenshots I tried to do while having this problem
  14. JAGADISH BHATTA
    Jelly Bean Apr 27, 2020
    JAGADISH BHATTA , Apr 27, 2020 :
    PUBG in itself is a very heavy game and you are playing it while charging if you love your phone please don't play games while charging
    Artemus likes this.
  15. Abhishek.001
  16. Artemus
    Community Hero 2020 Apr 27, 2020
    Artemus , Apr 27, 2020 :
    Yes... and just because you didn't get it doesn't mean you're never gonna get it.
    drl431 and Auristic like this.
  17. Abhishek.001
  18. B_Wrath
    Nougat Apr 27, 2020
    To everyone facing the problem of Google play crashes and unable to access the storage, try installing 10.3.3 again. This will change the partition access. Might help. Also, you won't lose data.
    Let me know if it works out.
    Auristic, Federico Martin and Artemus like this.
  19. NodePoint
    NodePoint , Apr 27, 2020 :
    I took a look at the logcat to see wtf was going on with the system.
    It's turns out, the SQLite database for the Downloads Provider (involved in reading and writing data to internal [emulated] storage) had a higher version in beta 6 when it wanted a lower version in 10.3.3 (looks like it may have failed to downgrade due to the database being in use constantly [locked]) and so Android naturally ends the process (crashing involved apps, if it's not handled).[​IMG]
    To fix this, search for the 'Download Manager' app in the settings, force close the app and clear its data.
  20. Lupastro82
    Yep (full rom, obviously).
