249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. drigovegas
    Eclair Apr 27, 2020
    drigovegas , Apr 27, 2020 :
    that didn't work.
  2. B_Wrath
    Nougat Apr 27, 2020
    B_Wrath , Apr 27, 2020 :
    Yup. Apparently, clearing the data of the downloads apps and download manager fixed the issue.
    Auristic likes this.
  3. rockpizzulo
    Eclair Apr 27, 2020
  4. drigovegas
    Eclair Apr 27, 2020
    that didn't seem to work either. Sorry.
  5. rockpizzulo
    Eclair Apr 27, 2020
    rockpizzulo , via OnePlus 6T , Apr 27, 2020 :
    Yes but, just for curiosity, how can I clear this data?
  6. eliamarisio
    Gingerbread Apr 27, 2020
  7. Kuronosu
    Froyo Apr 27, 2020
  8. drigovegas
    Eclair Apr 27, 2020
    this worked!!!!
  9. rockpizzulo
    Eclair Apr 27, 2020
  10. drigovegas
    Eclair Apr 27, 2020
    I cleared cache and storage for the download and download manager apps.
  11. Sanchit24ag
    Froyo Apr 27, 2020
    Sanchit24ag , via OnePlus 6 , Apr 27, 2020 :
    Yeo, clearing data of downloads and download manager fixed the issue.
  12. B_Wrath
    Nougat Apr 27, 2020
    Go to apps and notification, locate the downloads app and clear the cache and data in the storage option.
    rockpizzulo likes this.
  13. Lupastro82
    Lupastro82 , Apr 27, 2020 :
    Isn't the first time we (beta users) switch to stable thanks to full room. So, we know can cause problem, but the problem isn't cause upgrade to full room, but (like explained by other user) an issue with a specific app. So, switch remain possible.
  14. B_Wrath
    Nougat Apr 27, 2020
    Yes. You can still switch. But the direct moving was the problem. That's why a proper rollback is always recommended.
  15. NodePoint
    NodePoint , Apr 27, 2020 :
    Oops. Named the wrong app. Updated the post. You will need to force close and wipe data for 'Download Manager'.
    drl431 likes this.
  16. B_Wrath
    Nougat Apr 27, 2020
    I have added your solution to the pinned post. Thanks for the effort in finding out the solution.
  17. Lupastro82
    Yep, all seems to be ok atm (Just except lockbox: I cannot see files and crash If I try to put other file inside it).
  18. Federico Martin
    Federico Martin , Apr 27, 2020 :
    Someone that has 10.3.3 full working on OP6T
    Great Job NodePoint!
  19. Lupastro82
    Indeed. I'll try download and nothing changed. Try download manager and fixed. Just because not sure, report both 😅😉
  20. DevaDcruz
    Froyo Apr 27, 2020
