250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. NodePoint
    Honeycomb Apr 27, 2020
    NodePoint , Apr 27, 2020 :
    Wiping app data for 'Download Manager' should fix this. Google Play can crash up-on launch because it is attempting to download app updates, which uses the internal [emulated] storage temporarily.
    Caoimhín likes this.
  2. Gokul7373
  3. NodePoint
    You can stay on it. But you won't get any more updates in terms of open beta.
    If you want to continue getting feature and security updates for the rest of the update lifecycle for this device, you will need to go from beta 6 to a 10.3.3 stable release (full update) and apply the solution mentioned earlier on regarding a technical issue after that dirty (no wipe) upgrade.. or use the rollback ZIP which will do a full wipe.
    Caoimhín and Gokul7373 like this.
  4. Alex_Madalin
    Donut Apr 27, 2020
    Alex_Madalin , Apr 27, 2020 :
    Hey, where do i find downloads app and download manager?
    Thanks
  5. drigovegas
    Eclair Apr 27, 2020
    drigovegas , Apr 27, 2020 :
    there's a fix. check pinned post at begining.
    you need to clear cache and storage for the app called download manager.
    Caoimhín and Alex_Madalin like this.
  6. drigovegas
    Eclair Apr 27, 2020
    check pinned post. clear cache and storage for the app called download manager and it will fix everything.
    Caoimhín, Ronesso17 and Alex_Madalin like this.
  7. Source Unknown
    Donut Apr 27, 2020
    aakashmaji16 likes this.
  8. mayank gaur
    Cupcake Apr 27, 2020
    mayank gaur , Apr 27, 2020 :
    i m receiving this message while trying to install stable os
    please help me out ..i already downloaded rollback package but it's not working
    please help me out
  9. Vasant Wadile
    Froyo Apr 27, 2020
    Vasant Wadile , via OnePlus 6 , Apr 27, 2020 :
    mayank gaur
    please help me out​
    Downgrading package have file name end with .jar
    Please change this with . zip and check out you will find the package.
  10. sonu0502
    sonu0502 , via OnePlus 6T , Apr 27, 2020 :
    hi I'm facing problem on my one plus 6t...
    problem is that during the call I'm phone hang up automatically during the call... what should i do.....
  11. NodePoint
    Go to settings, use the search button and type 'download manager'. When it shows up on the list, press on it and follow the rest of the instructions.
  12. mayank gaur
    okk thanks i am going to try
  13. Alex_Madalin
    Donut Apr 27, 2020
    Alex_Madalin , via OnePlus 6T , Apr 27, 2020 :
    Thanks. I switched to english in order to find it.
  14. mayank gaur
    I changed into .zip extension but it's showing the same
  15. Vasant Wadile
    Froyo Apr 27, 2020
  16. mayank gaur
    if possible can you please send me the correct link of rollback
    as i remember i downloaded from some YouTube link as it of 1.60 gb.
    thanks
  17. T1527608809570
  18. Vasant Wadile
    Froyo Apr 27, 2020
  19. mayank gaur
  20. Vasant Wadile
    Froyo Apr 27, 2020
    Please back up your data before proceeding...rollback will wipe your all data. I have shared link for oneplus 6.
