249
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. benjamin.reveille , via OnePlus 6T , Apr 28, 2020 :
    i justed reflashed the modem.img (with fastboot) from 10.3.2 and got it back... so it is an issue with the 10.3.3 modem.img
    Am chatting with oneplus support... First reply is not raising my hopes it will be useful as I am being told the 6 does not support volte...
    Caomhin likes this.
  2. B_Wrath
    Nougat Apr 28, 2020
    B_Wrath , Apr 28, 2020 :
    Beta never has staged rollout. Only the stable build does.
    Caomhin, Artemus., rhyd1am and 2 others like this.
  3. Abd007
    Eclair Apr 28, 2020
  4. Garzino
    Gingerbread Apr 28, 2020
  5. Joseph325
    Eclair Apr 28, 2020
    Joseph325 , Apr 28, 2020 :
    its the second time I got system ui crashes and required a restart for functioning. no idea what is wrong with the current update,screen flickers for a while
  6. batutu
    Eclair Apr 28, 2020
    Caomhin and prkoparkar like this.
  7. Sandeepbaral
    Cupcake Apr 28, 2020
    Sandeepbaral , via OnePlus 6T , Apr 28, 2020 :
    after updating to recent 10.3.3 i am facing serious problems in my 6T ..playstore and google photos app doesn't open..phone app also not working...pls help me how could i downgrade to beta 6..???
  8. Cervantes
    Lollipop Moderator Apr 28, 2020
    Cervantes , Apr 28, 2020 :
    Hi
    use this thread for update questions and comments
    Please, read the first post, beta has ended
    Use the search engine before opening a new thread
    Thread merged
    Artemus. and Caomhin like this.
  9. JAGADISH BHATTA and Caomhin like this.
  10. rhyd1am
    Jelly Bean Apr 28, 2020
    rhyd1am , via OnePlus 6T , Apr 28, 2020 :
    Read the pinned post at the top of this thread [e]2b06[/e]️[e]2b06[/e]️[e]2b06[/e]️
  11. DevaDcruz
    Froyo Apr 28, 2020
    DevaDcruz , via OnePlus 6T , Apr 28, 2020 :
    Guys. In OxygenOs updater, it shows 1.87GB for OnePlus 6T. I cant find the incremental file(242 MB). All I can do is to full update even though I'm in stable 10.3.2. Can you people help me to find a incremental file(not full package) for 6T. The full package is just useless for me.
    Dharmraj Jeurgi likes this.
  12. B_Wrath
    Nougat Apr 28, 2020
    Or you can wait for the OTA in your phone.
    Caomhin likes this.
  13. rHITkM.
    Honeycomb Apr 28, 2020
    rHITkM. , via OnePlus 6 , Apr 28, 2020 :
    Please follow every steps in pinned post in this thread by @B_Wrath. if after reading the pinned post , you still can't find Download and Download Manager then simply searched them in the settings.
    open File Manager app then tap on Storage then tap on Internal Storage : the page which opens just after tapping the internal storage is the root directory and anything you paste here is saved as in root directory.
    Caomhin and B_Wrath like this.
  14. Pepa1977
    Froyo Apr 28, 2020
    Pepa1977 , Apr 28, 2020 :
    Hi, you can find it in the Oxygen update application
  15. DevaDcruz
    Froyo Apr 28, 2020
    Incremental update option is selected in OXYGENOS Updater. but still I'm getting 1.87 GB full update and not incremental actually.
  16. AvdhutAtkale97 , via OnePlus 6 Mirror Black , Apr 28, 2020 :
    Done that thing also still the problem persists. I will report bug via feedback. Thanks for help.
    rHITkM likes this.
  17. Caomhin
    Marshmallow Apr 28, 2020
    Caomhin , via OnePlus 6T , Apr 28, 2020 :
    That sounds like a good fix. Hopefully OnePlus listen to you.
    Just a side note though, I wonder would that break the new Jio VoWiFI feature and, or Danish VoWifi feature if someone were to try it.
    Glad you found a solution. Kudos to you [e]1f601[/e][e]1f44d[/e]
    rHITkM likes this.
  18. benjamin.reveille , via OnePlus 6T , Apr 28, 2020 :
    For sure it would as they are not supported in 10.3.2's modem.img...
    Caomhin and rHITkM like this.
  19. Yannis Neris
    Ice Cream Sandwich Apr 28, 2020
    Yannis Neris , Apr 28, 2020 :
    Yes..
    10.3.3 running great for me..
    Coming from latest beta6( OP6T)
    If you're facing issues after boot , wipe data from downloads and download manager apps
