250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. rohitsharma_j22
    Gingerbread Apr 29, 2020
    rohitsharma_j22 , Apr 29, 2020 :
    Thanks Buddy. Thats the only reason I hvn't switched to stable yet. OB6 itself is very stable with lots of features. I think its the better option to wait for 10.3.4
  2. rohitsharma_j22
    Thanks Buddy...
  3. Feejus
    Feejus , via OnePlus 6T , Apr 29, 2020 :
    Antoine L
    why no features anymore​
    I am not trying to be funny here, but did you ever think that writing code and providing updates does requires collaboration and we have a epic pandemic across the globe.
    Also I would say 10.3.2 was relative buggy so can only assume they fixed the bug before moving to new features.
  4. Feejus
    jerryjoseph82 likes this.
  5. G_Dhanapal_mEPD and Caomhin like this.
  6. Feejus
    You are aware that if you are on beta and move to final build it will wipe all of you data? It's all over this page and elsewhere?!
  7. prakash_70
    Cupcake Apr 29, 2020
  8. abhijeetbamel
    Eclair Apr 29, 2020
    ramesh.dilin likes this.
  9. Pepa1977
    Froyo Apr 29, 2020
    Pepa1977 , Apr 29, 2020 :
    I crossed without losing data
    Caomhin likes this.
  10. Twiny
    Eclair Apr 29, 2020
    Twiny , Apr 29, 2020 :
    Updated to 10.3.3 before performing a factor reset and my 6t is working flawlessly absolutely no complaints whatsoever 😁
    Caomhin likes this.
  11. souravka6
  12. Cervantes
    Moderator Moderator Apr 29, 2020
    Cervantes , Apr 29, 2020 :
    Hi
    Please, use this thread for questions and comments on this update and read the first post
    when it's your turn to update
    use the search engine before opening a new thread
    Thread merged
    Caomhin likes this.
  13. adi1001
    Honeycomb Apr 29, 2020
    adi1001 , via OnePlus 6T , Apr 29, 2020 :
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e]brother when u migrate from beta to stable channel it wipes ur data and storage......now u forget ur pics ...
  14. Tee_Eee_Bee
    Ice Cream Sandwich Apr 29, 2020
    Tee_Eee_Bee , via OnePlus 6T , Apr 29, 2020 :
    Feejus
    You are aware that if you are on beta and move to final build it will wipe all of you data? It's all over this page and elsewhere?!​
    So long as the stable version you are installing has a newer build date than your beta version, you shouldn't lose any data. I went from OB 6 to 10.3.3 without losing data, although I did do a factory reset a few hours after the upgrade.
    Having said that, it's good practice to back up your data prior to updating anyway.
    Also, it seems that a lot of issues are resolved by doing a factory reset after updating, so if you do back everything up, then this won't cause issues either.
    drl431, Caomhin, Feejus and 3 others like this.
  15. Varun Narayan
    Froyo Apr 29, 2020
    Varun Narayan , via OnePlus 6 , Apr 29, 2020 :
    No it doesn't, if you update from beta to a higher version of the OS it won't wipe your data, I just did so with no data loss
    if you still have questions, please read the information given in the pinned comment
  16. Federico Martin
    Federico Martin , Apr 29, 2020 :
    I think I will factory reset my phone there's some glich in phone app, settings, spam, block by keyword: the app crash...
  17. rhyd1am
    KitKat Apr 29, 2020
    rhyd1am , via OnePlus 6T , Apr 29, 2020 :
    what version of the phone so are you using?
    Caomhin and Federico Martin like this.
  18. Alikhan324 , via OnePlus 6 Midnight Black , Apr 29, 2020 :
    yes!!! first time i have seen this error.. anyways js curious that anyone who have received the oneplus roaming update?
  19. Federico Martin
    V. 4.4.1 I've update from OB6 to stable 10.3.3 I think some apps in OB6 version is not overwrited on stable 10.3.3 maybe I need flash twice (I don't think so)?
    rhyd1am likes this.
  20. rhyd1am
    KitKat Apr 29, 2020
    Same version here, mine is working fine. Although I rolled back to 10.3.2 first (which involved a full wipe), so perhaps that's why.
    I'd give it a go and reset
