250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. konatham anil
    Eclair Apr 30, 2020
    konatham anil , via OnePlus 6 , Apr 30, 2020 :
    ok i will
  2. Feroz_Mohammed
    Gingerbread Apr 30, 2020
  3. LoveThakur
    Froyo Apr 30, 2020
    LoveThakur , Apr 30, 2020 :
    Yes I did, I talked to them over the chat support and they dont have any solution for this. Representative arranged a call back for me
  4. B_Wrath
    Junior Moderator Junior Moderator Apr 30, 2020
    B_Wrath , Apr 30, 2020 :
    This bug is not due to rollback. He has manually updated the dialer app.
    Caoimhín and Auristic like this.
  5. supinder8328
    Cupcake Apr 30, 2020
  6. B_Wrath
    I told you. It's not there!
    kjjm, Caoimhín and Auristic like this.
  7. Feroz_Mohammed
    Feroz_Mohammed , via OnePlus 6 , Apr 30, 2020 :
    I'm thinking to rollback to beta again to get my data back. there's something shit happening after I rollbacked to stable.
  8. LoveThakur
    Froyo Apr 30, 2020
    dialer version no. is 4.9.1
  9. B_Wrath
    That post was not meant for you. Check who is quoted before replying.
  10. rockpizzulo
    Eclair Apr 30, 2020
    rockpizzulo , via OnePlus 6T , Apr 30, 2020 :
    Currently it seems that this issue is disappeared, but sometimes it happens and then it returns :(
  11. B_Wrath
    I told you. You have manually installed a dialer app not meant for your device! Don't do those kind of things!
  12. Feroz_Mohammed
    hey, nice to see u quoted me. u switched to stable from beta? facing any issues?
  13. konatham anil
    Eclair Apr 30, 2020
    the problems are not with rollback file, problems are with oneplus switch app and remaining apps (which are installed apks externally)
  14. B_Wrath
    If it disappears, then it is definitely some third party app causing this. The next time you see the alarm notification, check which app trigerred it.
  15. supinder8328
  16. rockpizzulo
    Eclair Apr 30, 2020
    How can I do to check which app trigger it?
  17. B_Wrath
    It has been removed.
  18. Feroz_Mohammed
  19. B_Wrath
    Try triggering one app after the other. If after any app is opened and the alarm function shows up, that app is the culprit.
  20. Feroz_Mohammed
    externally?
