250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. supinder8328
    Cupcake Apr 30, 2020
  2. rockpizzulo
    Eclair Apr 30, 2020
    rockpizzulo , via OnePlus 6T , Apr 30, 2020 :
    But I can see that also with all the app closed
  3. konatham anil
    Eclair Apr 30, 2020
    konatham anil , via OnePlus 6 , Apr 30, 2020 :
    means they are not download from play store,They are the application which are downloaded from some websites or forums
  4. B_Wrath
    Junior Moderator Junior Moderator Apr 30, 2020
    B_Wrath , Apr 30, 2020 :
    With all app closed, the process is still running in the background. Sometimes, the process gets killed after a duration of inactivity. Maybe that's the time your icon disappears.
    Caoimhín and Auristic like this.
  5. rockpizzulo
    Eclair Apr 30, 2020
    Yes, but so I can't check triggering every app
  6. wheelie101
    Froyo Apr 30, 2020
    wheelie101 , Apr 30, 2020 :
    I use OnePlus Messaging app and it restored all my messages from the Google backup so yes it works.
    Can you please elaborate on the pic backup? Did you mean backing up in Google Photos? I assume nothing would come back to Gallery after a factory reset and restore from Google backup?
  7. B_Wrath
    No. I mean, now try opening one app after the other and monitor the icon. If an icon comes up while you open an app, that's the app causing this issue.
    Caoimhín, rockpizzulo and Auristic like this.
  8. supinder8328
  9. B_Wrath
    ironass and Auristic like this.
  10. supinder8328
    supinder8328 , via OnePlus 6 , Apr 30, 2020 :
    no m not want app to use data while it is in background bocz battery life
  11. B_Wrath
    Then keep it off. What is the confusion there?
    Caoimhín, Auristic and rhyd1am like this.
  12. supinder8328
  13. B_Wrath
    Auristic likes this.
  14. Pankaj_88
    Froyo Apr 30, 2020
  15. supinder8328
    B1548577121166 likes this.
  16. LoveThakur
    Froyo Apr 30, 2020
    LoveThakur , Apr 30, 2020 :
    I didn't manually update but yeah I used a third party app to update my applications.
  17. supinder8328
  18. FaleshC
    KitKat Apr 30, 2020
    mayrsona and Auristic like this.
  19. B_Wrath
    Using a third party app is called manually updating.
    Do not update system apps manually.
  20. supinder8328
