250
OxygenOS 10.3.3 for the OnePlus 6 and 6T
  1. supinder8328
    Cupcake Apr 30, 2020
  2. Pankaj_88
    Froyo Apr 30, 2020
  3. supinder8328
  4. B_Wrath
    Junior Moderator Junior Moderator Apr 30, 2020
    Auristic likes this.
  5. rhyd1am
    KitKat Community Expert Apr 30, 2020
    rhyd1am , via OnePlus 6T , Apr 30, 2020 :
    With active usage being 8.5hrs that is the problem. There was only 6 minutes of background usage. Any option you select there will only affect background usage not active usage.
  6. supinder8328
  7. supinder8328
    supinder8328 , via OnePlus 6 , Apr 30, 2020 :
    u mean m used 2nd option
  8. rhyd1am
    It means what it says. It will adapt it's optimization, according to your usage
  9. cruzAD
    Gingerbread Apr 30, 2020
    cruzAD , Apr 30, 2020 :
    Chinese can't step over their shadow. It's a Chinese phone.
    iamrj likes this.
  10. supinder8328
  11. supinder8328
  12. rhyd1am
    Well the best option for battery life, is to have it set to optimise.
    Although the reason your battery life has taken such a hit is because of the 8.5 hours you've been playing PUBG. Optimising background usage won't affect that.
  13. rhyd1am
    It is a staged random rollout. Just be patient and it will come to you in due course.
    Skoreykom, Auristic and Caoimhín like this.
  14. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 30, 2020
    Caomhin , via OnePlus 6T , Apr 30, 2020 :
    They are the same as I currently have on 6T, 10.3.3 , Launcher version 4.4.2.
    Sahilk0369 and Auristic like this.
  15. Caomhin
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    Auristic and rhyd1am like this.
  16. Caomhin
    Yes Google Photos is now separate from Google Drive. So it's a matter of using Google photos for you photo backup only. The rest will backup to Google drive through Google backup. Although you can enable, disable photos option from Google backup settings as well.
  17. Caomhin
    Rollback again will do nothing other than wipe your phone again, there will be nothing to retrieve.
  18. Caomhin
    ROLL-BACK FROM CURRENT ANDROID 10 Beta or Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    If you can, you could try a Full Factory Reset to fix the issue. Steps below to Factory Reset the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Your phone will now restart and go through the Full reset cycle.
    And its always good practice to backup phone data before upgrading.
    cruzAD, ironass and Auristic like this.
  19. Tejas Tharu
    Tejas Tharu , Apr 30, 2020 :
    Sorry, I couldn't agree at all. I like the way how beautifully Apple's iOS & Google's Stock Android Roll-out works. Global roll-out in a single day at a single time, Period.
    Panos1988 likes this.
