305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 10, 2020
  2. TejasDwivedi
    Eclair Jun 10, 2020
    TejasDwivedi , Jun 10, 2020 :
    this update is glitchy I suppose, cause the dark theme is not working properly on my device now
  3. V1576940755431
    Cupcake Jun 10, 2020
  4. S1537368925336
    Eclair Jun 10, 2020
    S1537368925336 , via OnePlus 6 , Jun 10, 2020 :
    Is it just me or the more later updates the more the os is getting more incompatible with the previous version for example OP6/T?
    They're starting to show their age and all. I'm still rock op6 BTW and the battery is not as good as it used to, kinda like the battery is getting degrading or the is might be at fault at this or something but anyways, it's good to see op still supporting older gens.
    My suggestion to op, pls do something to the battery life first . We can't use them without battery juice. Thank you.
  5. ItsRavi25
    Jelly Bean Jun 10, 2020
    ItsRavi25 , via OnePlus 6T , Jun 10, 2020 :
    Will you explain in detail... about the glitch....
    What things you're expecting?
    Caoimhín likes this.
  6. TejasDwivedi
    Eclair Jun 10, 2020
    the overall experience has become less smooth, Google apps now appear to be more grayish-dark and that's it.
  7. ItsRavi25
    I think you're the one who is facing the problem..and it is not the software problem.
    Try to check the adapter and cable......
    V1576940755431 and Caoimhín like this.
  8. Caomhin
    Caomhin , via OnePlus 6T , Jun 10, 2020 :
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully
    See if that helps.
    V1576940755431 likes this.
  9. Caomhin
    If you have the phone and battery 2 years it's possible there could be degradation, all depends on how it's used, customised in fact many variables can affect it, climate even.
    However you could try the following and see if it helps to Optimise what you have.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    ironass, V1576940755431 and ItsRavi25 like this.
  10. ItsRavi25
    Goto settings>Customisation>Preset theme>select Illuminating Light> Apply>again select Nuanced dark and apply...
    For smoothness clear caches of OnePlus launcher or update latest version launcher if not updated....
    if you're still facing the problem...
    As per my opinion and some Experts in this forum you should try to reset (Factory reset) your device..
    Backup first 😇
  11. TejasDwivedi
    Eclair Jun 10, 2020
    Done that ✅✅ still no good
  12. ItsRavi25
    Then backup your data and go for factory reset.. this will definitely solve your all problems
  13. TejasDwivedi
    Eclair Jun 10, 2020
    I'll try that first thing tomorrow morning
  14. M1535016326738
    D1540005096089 likes this.
  15. Royal_RJ
    Ice Cream Sandwich Jun 10, 2020
    Royal_RJ , via OnePlus 6 , Jun 10, 2020 :
    This is perfect thing to OnePlus 6 series.
    "RIP" is perfect word for this series because many user's still facing issues in their phone and which update we get they are not satisfactory because of many reason. update is not recieved on time if recieve then their is many issue. everytime bettary heating issue is same. we have 20 + 16 megapixel phone but images are not satisfactory.
    Many feature are not added yet and I am sure that in future they are not added.
    overall now time to upgrade / switch the company. in this stage I have 2 options :- 1. iphone ( SE 2 )
    2. Google phone's
    This is my opinion and I think there is no issue for those who always wait for any post against this brand before this series of phone I was also like them.
    Trevor.Hawkes likes this.
  16. _BlackPanther_
    Honeycomb Jun 10, 2020
    _BlackPanther_ , Jun 10, 2020 :
    It would be helpful for you when you have formatted your phone and use gcam for camera rather than spending time here posting rip pictures.
    Feel free to use whatever phone you like, don't wait for it, switch asap.
  17. Royal_RJ
    _BlackPanther_
    Feel free to use whatever phone you like, don't wait for it, switch asap.​
    one more is added in that list and why we use other camera apps to click picture it means your apps are not satisfactory because phone and camera is same but app makes change.
    Here your apps mean you are stand infornt of me behalf of OnePlus.
    welcome
  18. Q1532279309122
  19. _BlackPanther_
    Not sure what you trying to say, I am a user like you, and gave you some options to consider.
    Take it or leave it , it's upto you.
  20. _BlackPanther_
    There are others options you could use to get it. Or wait for ota.
