305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    Marshmallow Jun 11, 2020
  2. ciocip81
    Cupcake Jun 11, 2020
  3. Ján Hirner
    Gingerbread Jun 11, 2020
    rHITkM, Caomhin and ciocip81 like this.
  4. Intekhab145
    bakshi.arnab likes this.
  5. Caomhin
    Caomhin , via OnePlus 6T , Jun 11, 2020 :
    Ján Hirner
    5.0.0 is beta Extracted from OnePlus 8 Pro R DP1, last stable version is 4.5.2​
    I would suggest maybe NOT to try 5.0.0 as it's for a different version of Android. And many apps created for OP8 Android 11 preview will NOT work on Android 10. It may bork the app, and even mess up other items.
    I have 4.5.2 installed and its working fine.
    rHITkM, ItsRavi25, Artemus. and 2 others like this.
  6. Caomhin
    Intekhab145, Artemus. and ironass like this.
  7. EL1TxE
  8. Jacob Bearman
    Cupcake Jun 12, 2020
  9. Raise
    Raise , Jun 12, 2020 :
    i am not receiving OTA based updates any longer.
    what should i do
  10. Tee_Eee_Bee
    Honeycomb Jun 12, 2020
    Tee_Eee_Bee , Jun 12, 2020 :
    What version are you currently on (stable or Open Beta)?
    If still on Open Beta, then you won't receive an OTA until you move back to a stable build as Open Beta has currently ceased for OP 6 series.
    Otherwise, as has been mentioned, you either hurry up and wait, or (as has been suggested numerous times already in this thread):
    1. Use Oxygen Updater (3rd party app available from Play store) and download and install
    2. Use the links in this XDA post to download and manually install
    https://www.xda-developers.com/oxyg...work-life-balance-epic-games-store-india/amp/
    Caomhin and Artemus. like this.
  11. ItsRavi25
    Ice Cream Sandwich Jun 12, 2020
    Caomhin likes this.
  12. aboodabbad
    bakshi.arnab and CSR! like this.
  13. Artemus.
    Nougat Jun 12, 2020
    Artemus. , Jun 12, 2020 :
    What version are you on now?
    Caomhin likes this.
  14. aboodabbad
  15. Artemus.
    Nougat Jun 12, 2020
    Then wait. It can take up to a month to reach everyone. If you can't wait, Oxygen Updater is your best choice.
    drl431, ItsRavi25 and Caomhin like this.
  16. E1544196160689
    Gingerbread Jun 12, 2020
  17. Tejas Tharu
    Tejas Tharu , Jun 12, 2020 :
    By looking at your battery stats, it is showing 33% left.
    Now, considering the fact that it lasted for ~3 hours, with 67% consumed.
    Have done simple math, it is telling with the remaining 33%, it will go for another ~1 hour and 30 minutes. Overall your SOT will be 4 hours 30 minutes and keeping your 15 minutes as margin.
    I believe that, nothing has changed, just give it few days to get settled, and hopefully you will see better results.
    If you are still not satisfied with the Battery backup, consider a replacement.
    Caomhin, Artemus. and E1544196160689 like this.
  18. TeMpL
  19. W1557160892925
    Donut Jun 12, 2020
