305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert May 28, 2020
    Caomhin , via OnePlus 6T , May 28, 2020 :
    contact OnePlus support directly to see if they have more information about those new features. They should be able to help you with that.
    Scroll down the page for contact and online chat details.
    N1594291477985 likes this.
  2. sirgeorge1973
    Froyo May 28, 2020
    Caomhin likes this.
  3. Ruy_peixoto
    Froyo May 28, 2020
    Caomhin likes this.
  4. Caomhin
  5. Caomhin
    That would be different hardware, hardware can't be swapped out. Unless they figure out a way through software, but current 6 Series physical camera may not be capable of doing that.
    drl431, ironass, rHITkM and 1 other person like this.
  6. SaranRaj Sharma
    Froyo May 28, 2020
  7. Di Cortado
    Cupcake May 28, 2020
    Di Cortado , via OnePlus 6 , May 28, 2020 :
    Will this sort the battery drain issue I've had since update to 10.3.3? Experiencing massive drain, 44 % overnight with phone locked. Doesn't last even half day with normal everyday use. Had no problems with battery when moving from Oxygen beta to 10.3.2.
  8. Attached Files:
  9. Caomhin
    drl431 likes this.
  10. AndrewPadley
  11. Miguel Quezada
    Jelly Bean May 28, 2020
  12. Caomhin
    No, 6 and 6T have different OOS Rom builds same for all the other series, as there are slight differences in each model of phone within the series.
    drl431 likes this.
  13. S1531502170183
    Eclair May 28, 2020
  14. Caomhin
    You would have to ask OnePlus developers directly about that. Only Users in these forums.
  15. Caomhin
  16. Satyajeet Ghosh , via OnePlus 6T Mirror Black , May 28, 2020 :
    Please add hyperlapse and improve the selfie camera in OnePlus 6T. When your background is well lit the selfie camera is not able to capture much detail(background becomes fully white and If you tap on the background the subject becomes black🥺)
  17. SaranRaj Sharma
    Froyo May 28, 2020
    SaranRaj Sharma , via OnePlus 6T , May 28, 2020 :
    yeah. I also got the battery draining issue. my battery is draining faster than before.
  18. SaranRaj Sharma
    Froyo May 28, 2020
  19. Suraj3000
    Gingerbread May 28, 2020
    Bintang12 likes this.
  20. DhavalBhuva
    DhavalBhuva , via OnePlus 6T , May 28, 2020 :
    I'm on 6t beta... should i downgrade to 10 3.2 or go with oxygen updater and install 10 3.4 directly...plz guide
