305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. cherry82505
    Cupcake Jun 19, 2020
  2. mohal
    Ice Cream Sandwich Jun 19, 2020
  3. cherry82505
  4. cherry82505
  5. Tee_Eee_Bee
    Tee_Eee_Bee , Jun 19, 2020 :
    This might work, it's from a previous post about this issue from 2019:
    "search for downloads in the settings and go to storage and click on clear cache"
  6. MasterManish
  7. Koushik87
    Gingerbread Jun 19, 2020
    Koushik87 , via OnePlus 6T , Jun 19, 2020 :
    It happens when you confgure your whatsapp before contacts. Whatsapp syncs the contact name from your contacts. Try uninstalling whtsapp, sync ur contacts from google backup or local.Then reinstall whatsapp. I have faced same issue earlier and this solution worked.Make sure your latest backup of whatsapp is available to get all your chat history and media back. Clearing the contacts and whatsapp cache may also help.
    drl431 and Caomhin like this.
  8. MasterManish
    MasterManish , via OnePlus 6 , Jun 19, 2020 :
    yeah its working.. thanks bro for help..
    drl431 likes this.
  9. A1581281292027
  10. Ján Hirner
    Honeycomb Jun 19, 2020
    Ján Hirner , Jun 19, 2020 :
    At first you have to know (maybe you know it yet): After the Android Pie update, Google has strictly restricted call recording. This makes it hard for the apps to record the calls clearly. In our testing, Cube Call Recorder was the only app that worked flawlessly on Stock Android, OnePlus, Xiaomi, and other phones that we tested it on. The app was working even on Android phones running Android 10.
    As for other apps, some of them were working on Stock Android, some on Samsung, and some on OnePlus. So the bottom line is that you have to install the apps and check if its working on your device or not. I suggest that you start with using “Cube Call Recorder ACR” and then move onto other apps if it’s not working.
    Also, make sure to grant any permissions asked by these apps if you want to record calls. For the best recording experience, open the App Settings and select “Voice Recognition Software” as the input option instead of the default “Voice Call” options. Make sure to go through the Settings of apps and configure it for best recording experience.
    Maybe someone knows working app on oneplus 6/6T...I am affraid there isnt any 100% reliable app ...
  11. Harsh_Hinsu
    Harsh_Hinsu , Jun 19, 2020 :
    Regarding charging issue
    This is Harsh Hinsu, I am using OnePlus 6T and I am facing problem in charging. When I put on charging after few time it automatically stops and then I have to again restart the device then it gets solved,but this is happening everytime so I am feed up with this. Can you help me any conditions.
    Hope you understand the situation.This is happening after I got 10.3.3 update.
  12. karthick3889
  13. kdpatil45
    kdpatil45 , Jun 19, 2020 :
    I think font is broken, some part of app shows roboto and some part shows slate font.
    I have set slate my default font
  14. Ján Hirner
    Do local update 10.3.3 (i recomend full), at first back up your files, next dont forget wipe cache after update, if doesnt help I recommend do factory reset, see if it helps
  15. ItsRavi25
    Jelly Bean Jun 19, 2020
    ItsRavi25 , via OnePlus 6T , Jun 19, 2020 :
    just clear the cache and storage of launcher and reboot the device...
    Caomhin likes this.
  16. Caomhin
    OnePlus 9 Series Expert Community Expert Jun 19, 2020
    Caomhin , via OnePlus 6T , Jun 19, 2020 :
    Clear all screen locks, Pin, Face, Fingerprint
    Restart the phone and you should get the Fingerprint option back.
  17. Caomhin
    Clear all Screen locks, Pin, Face, Fingerprint etc, restart the phone and setup the Fingerprint again.
  18. ASMITSHARMA
  19. Caomhin
  20. dev_aashish_
    Eclair Jun 19, 2020
