305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. jeeshan1143
    Cupcake Jun 23, 2020
    jeeshan1143 , Jun 23, 2020 :
    see, I never had a issue with speed 🤷
  2. Caomhin
    Marshmallow Jun 23, 2020
    Caomhin , via OnePlus 6T , Jun 23, 2020 :
    You mentioned you had Battery, Lag and App crash issues, that's why I suggested doing the steps in the post above, hopefully it will relieve a lot if not all of those issues.
  3. jeeshan1143
    thanks for your support , lag in face unlock when I tried to unlock beside a light source or in background ... any suggestions
    Srínívas Sñ likes this.
  4. anup1111
  5. I1548089682366
    Donut Jun 23, 2020
    I1548089682366 , Jun 23, 2020 :
    After the latest update on my op6t, and using it for two weeks now i can definitely say that the battery backup is definitely not that good. I have tried all the settings and everything. i have cleared cache and enabled battery optimization but while playing pubg and at 100% battery after playing 90 min it is at 35%. phone heats a lot. Gaming performance of the phone is not that great now. Even when i don't play pubg it is still going down very fast. I am facing this battery issue and heating issue more while on roaming, as i am on roaming for past 5 days. 1592910404917.jpg
  6. ItsRavi25
    Ice Cream Sandwich Jun 23, 2020
    ItsRavi25 , via OnePlus 6T , Jun 23, 2020 :
    Which version you're using ? Try to contact OnePlus support or use Oxygen updater....
    Caomhin likes this.
  7. anup1111
  8. Caomhin
    Face unlock can be a bit hit and miss depending on lighting, not much to do about that, and it's not a secure way of locking the phone, check the Web to find out why.
    Remove all unlocks, face, Fingerprint, pin etc. Also remove all Smart Locks as well.
    Clean the are around the camera with a lint free clean cloth .
    Restart the phone, then setup the Face Lock again. See if that helps.
    drl431 likes this.
  9. Caomhin
    drl431, Auristic and ItsRavi25 like this.
  10. Hmoda_Alex
  11. lazarb
    lazarb , Jun 23, 2020 :
    Hey, just updated to 10.3.4 on my OnePlus 6 and Android Auto refuses to work. Starts for a few seconds then car says it could not connect. If I try again, I get a notification on the phone that no application is installed for the connected accessory.
    I've just reset the phone, clean install, still not working.
    Anyone else experience this? Are there any known issues or workarounds?
  12. ItsRavi25
    Go through this post..may be this will helpful for you. https://oneplustips.com/fix-android...: Swipe down until,time you connect the phone.
    Caomhin likes this.
  13. viveksinhaxp
    Eclair Jun 23, 2020
  14. S1541767555421
    Eclair Jun 23, 2020
    S1541767555421 , via OnePlus 6T , Jun 23, 2020 :
    Hmmmm. As I'm reading most comments I consider my self lucky. Must be user or perfect hardware side. When I find out what is a cause of trouble free unit I let you guys know. Cheers.
    kjjm, Naveen_006 and Auristic like this.
  15. Auristic
    KitKat Jun 23, 2020
    Auristic , Jun 23, 2020 :
    Maybe it's because you know what you're doing and don't blame your device for your own mistakes!
    Don't say too loud you've got no problem here or else you'll be called "fanboy" by the whining bunch...
    Remember that usually people who don't have issue don't whine.
    ItsRavi25, drl431, Caomhin and 3 others like this.
  16. A1550387522048
    Honeycomb Jun 23, 2020
    A1550387522048 , via OnePlus 6 , Jun 23, 2020 :
    Since 20 days I have 10.3.4 update and am so so satisfied. Either with battery life or wirh the speed and other computing services. Thanks oxygene team.
    kjjm, Caomhin, Auristic and 1 other person like this.
  17. A1550387522048
    drl431 and Caomhin like this.
  18. Arko Mustafi
    Eclair Jun 23, 2020
    Arko Mustafi , Jun 23, 2020 :
    yes buddy full wipe and I didn't use the OnePlus backup
    Caomhin likes this.
  19. Artemus.
    Nougat Jun 23, 2020
    Artemus. , Jun 23, 2020 :
    Did you restore a backup while setting it back up?
  20. Caomhin
    Those Security updates come with each build release, next build version should be out within the next couple of months. No rush. 10.3.4 is working very well.
    ItsRavi25 and Artemus. like this.
