283
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. E1593345291402
    Cupcake Jun 29, 2020
  2. E1593345291402
  3. iam_gj
    iam_gj , Jun 29, 2020 :
    After the system update, my OnePlus 6 device often hangs or the apps crash especially Chrome and Facebook. Also the "handling theme" notification from time to time are quite irritating. Is the app crash issue are faced by other users too?
  4. Srínívas Sñ
    Honeycomb Jun 29, 2020
  5. rhyd1am
    Jelly Bean Jun 29, 2020
    rhyd1am , via OnePlus 6T , Jun 29, 2020 :
    When did you update your device? It can take a little time for a device to settle down after any updates.
    You could try clearing the app data and cache for Chrome and Facebook to see if that helps with the crashing.
    As for the handling theme notification, you can do the following:
    Go to Settings, search Android System>Notifications>Advanced Long press FG OpThemesApkHandlerService Select Other instead of Important Select Minimize
    Deselect Override Do Not Disturb.
    Caomhin likes this.
  6. iam_gj
    Thanks on the notification solution. However for the apps crashing, I have tried clearing the cache but it didn't help much. I updated the device 9 days ago.
  7. Caomhin
    Lollipop Jun 29, 2020
  8. acyix
    Froyo Jun 29, 2020
    acyix , Jun 29, 2020 :
    I was on Android 9, but got on 10.3.3 using the update downloaded from the OnePlus site. However, system updates are still telling me I am up to date.
  9. rhyd1am
    rhyd1am , via OnePlus Community App , Jun 29, 2020 :
    Which device do you have?
    Caomhin likes this.
  10. D.Sai Suhail Baba
    Gingerbread Jun 29, 2020
    D.Sai Suhail Baba , Jun 29, 2020 :
    If you want Indian companies device then start your own company and manufacturing devices. Each and every electronic device parts and tools are manufactured in China. Even iphone parts are exported from China branch Foxconn. And later they are assembled in India. Even electronic devices hardware technology and software technology is also made by Chinese companies. If you want to promote Indian products then stop using Chinese products and start using Indian products and their parts should be manufactured in India only. Stop using OnePlus also as it is Chinese product. Try to make your own phone if needed.
  11. acyix
    Froyo Jun 29, 2020
    OnePlus 6T, A6013
  12. rhyd1am
  13. Royal_RJ
    Royal_RJ , via OnePlus 6 , Jun 29, 2020 :
    First you need to read my all post
    Kleb32 likes this.
  14. acyix
    Froyo Jun 29, 2020
    rhyd1am likes this.
  15. rhyd1am
    I've got no idea at all why it's not coming as an OTA for some people the last couple of days. It always takes time for OnePlus to post the update on the support page though.
    Personally I prefer updating manually using the full update where possible anyway, as I find there's less chance of bugs or issues that way
    drl431, Caomhin and acyix like this.
  16. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jun 29, 2020 :
    Ohh still there is issue...
    If you're facing this problem after updating to 10.3.4 then i think you should rollback to previous version ...
    Here is the guide link
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    Thanks to @ironass
    After rollback check everything is working fine ...if everything is ok the again update your device..as you will automatically get the update notifications. (If not received the update use oxygen updater).
  17. ItsRavi25
    E1593345291402
    Do u have mayby guide"how correct instal soft ?"
    This video will help you to easily understand how to clean install...
    youtu.be/vY4bMoOhYSo
    Download all drivers given in video description..
    Caomhin likes this.
  18. mohal
    Caomhin likes this.
  19. ItsRavi25
    I think !! May be you're using some packed fastboot rom...thats may be the reason you found these wallpapers...
    Because re-locking the bootloader will wipe your whole phone data.
    Caomhin likes this.
  20. mohal
    mohal , via OnePlus 6T , Jun 29, 2020 :
    ItsRavi25
    Because re-locking the bootloader will wipe your whole phone data.​
    I was on AOSP based custom roms and thought that I have to give a try to OOS . Looks good.
    Caomhin likes this.
