283
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Mohammed_Mustafa
    Donut Jun 29, 2020
    Mohammed_Mustafa , Jun 29, 2020 :
    Thanks for your reply everything is now fine......
  2. Archit@123
    Gingerbread Jun 29, 2020
    Archit@123 , via OnePlus 6T , Jun 29, 2020 :
    No u get this wallpaper when u use msm tool
  3. ItsRavi25
    Honeycomb Jun 29, 2020
    ItsRavi25 , via OnePlus 6T , Jun 29, 2020 :
    It is the same thing that the file that is installed is a fastboot ROM file, we do it by the msm tool.
    Caomhin likes this.
  4. Babyblue
    Cupcake Jun 29, 2020
    Babyblue , Jun 29, 2020 :
    where do I get help with not receiving text messages even after I did a factory reset.
  5. Caomhin
    Lollipop Jun 29, 2020
    Caomhin , via OnePlus 6T , Jun 29, 2020 :
    Check that your APN network settings are correct. You will need to check them with your mobile network service provider.
    ItsRavi25 likes this.
  6. Abhigk
  7. Babyblue
    thanks doing that now. by the way where do I find VPN?
    Caomhin likes this.
  8. ItsRavi25
    There might be some issue server as many users facing the update issue...
    Use oxygen updater for update....
    Caomhin likes this.
  9. ItsRavi25
    For VPN use some app available on playstore...
    And
    As Caomhin said you have to check you APN
    For APN.... Settings>Wifi & internet>sim network>selects the sim>Access Point Name (APN)> select your network services...reboot your phone.
    Caomhin likes this.
  10. Babyblue
    Thanks, itsRavi25 it is set. I even took it to the Verizon store and called tech support no results.
  11. K1577433634807
  12. bogdan.soare9
    Froyo Jun 29, 2020
    bogdan.soare9 , via OnePlus 6 , Jun 29, 2020 :
    Yeah so I switched back to OOS coming from Pixel Experience, but it isn't possible through TWRP without an USB OTG cable. What I did was: 1 remove PIN or PATTERN from Security 2 reboot to TWRP 3 wipe system, data, vendor, cache 4 flashed OOS 10.3.3 from internal storage 5 reboot to recovery 6 insert usb otg (formatted as NTSC) 7 flash the same OOS 10.3.3 from usb otg 8 factory reset 9 reboot system 10 landed in recovery and did another factory reset 11 booted OOS 12 installed 10.3.4 through local upgrade 13 relocked bootloader. I'm not responsible for the damage that may occur to your phone when trying to follow the afore mentioned steps. For me, it did the trick and now I'm back to the phone's original state.
    Naveen_006 likes this.
  13. rhyd1am
    Jelly Bean Jun 29, 2020
    rhyd1am , via OnePlus Community App , Jun 29, 2020 :
    Incremental OTA for 10.3.4 for the 6T
    https://otafsg1.h2os.com/patch/amaz..._OTA_045-046_patch_2005052113_8d874af7a32.zip
    Full OTA for 10.3.4 for the 6T
    https://otafsg1.h2os.com/patch/amaz...34_OTA_046_all_2005052113_26a111bd1040285.zip
    Download whichever you prefer (incremental or full), and install it via local upgrade
    Auristic and Caomhin like this.
  14. K1577433634807
  15. Huyghue
    Froyo Jun 29, 2020
    Huyghue , via OnePlus 6T , Jun 29, 2020 :
    Hi all did the update for oneplus 6and6t been halted ? because i flashed my device using the msm tool and got 10.3.2 and when i check for an ota nothing was found
  16. rhyd1am
    rhyd1am , via OnePlus 6T , Jun 29, 2020 :
    The links to install it manually (for the 6t) are provided 2 posts up from yours. Not sure why there seems to be so many people the last 2 days unable to get the update when checking 🤷‍♂️
    drl431 and Caomhin like this.
  17. Huyghue
    Froyo Jun 29, 2020
  18. rHITkM
    rHITkM , Jun 29, 2020 :
    Huyghue
    I inow i could uodate it manually but once its not available via ota i think there's a bug being fixed​
    It is still not available to you via ota?
  19. rHITkM
