283
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. rhyd1am
    Jelly Bean Jun 29, 2020
    rhyd1am , via OnePlus 6T , Jun 29, 2020 :
    Well since 10.3.4 was released over 1 month ago now, and the vast majority of this thread is regarding minor issues (most of which have solutions). It is more than reasonable to assume that the OTA had not been pulled due to a major bug of any sort with the release.
    Monirho, drl431 and Caomhin like this.
  2. Huyghue , via OnePlus 6T McLaren Edition , Jun 29, 2020 :
    Ok i want to believe that thats not the issue but ill wait a weeks or so amd see if it comes via ota
    rhyd1am likes this.
  3. Babyblue
    Cupcake Jun 30, 2020
    Babyblue , Jun 30, 2020 :
    I have tried everything. I can't receive text messages from any texting app. it must be a the up date. Do anyone know if they are working on it a fix. and when?
  4. Ján Hirner
    Gingerbread Jun 30, 2020
    Ján Hirner , Jun 30, 2020 :
    https://forums.oneplus.com/threads/...neplus-6-and-6t.1231896/page-71#post-21682096
    maxa10 likes this.
  5. Salvator88
    Salvator88 , Jun 30, 2020 :
    runs very good on 6 but had some problems connecting with a specific router/wifi that I was using for a long time. although it connected It said no internet.tried wipe cache wifi/network reset but still same. someone told me something about bandwidth changes on latest version.
    MCunha likes this.
  6. maxa10
    Eclair Jun 30, 2020
  7. ItsRavi25
    Honeycomb Jun 30, 2020
    ItsRavi25 , via OnePlus 6T , Jun 30, 2020 :
    You should check your router maybe the problem will be in router...if router is working fine...
    Then try to connect to OnePlus support.
    Caomhin likes this.
  8. mohal
  9. G1577248624049
    G1577248624049 , Jun 30, 2020 :
    Wallpapers backgrounds changes every time while connecting to WI-FI NETWORK possible to change the possibility
  10. ItsRavi25
    Clear the cahe and storage of OnePlus launcher
    Caomhin and G1577248624049 like this.
  11. M1590642380241
    M1590642380241 , Jun 30, 2020 :
    I'm using OnePlus 6 and after the recent June update, my phone has started heating up a lot and becomes non-operational also at times, which wasn't the case earlier.. Also, the battery has started draining too much. Kindly fix the issue.
  12. Caomhin
    Lollipop Jun 30, 2020
    Caomhin , via OnePlus 6T , Jun 30, 2020 :
    Backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, AND then COMPLETE the NEXT steps below to Optimize the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Once done, use the phone for a couple of days without adding apps to check for issues with just the raw fresh OOS only.
    Only introduce previous 3rd party apps gradually over 2 weeks to see if any particular app or apps drain the battery
    https://www.androidpolice.com/2020/05/14/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    To Optimize the phone after a Reset, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    drl431 likes this.
  13. M1590642380241
    But that's practically not possible since it's an important data.. and the steps mentioned here are even worse than buying a new phone. Can't there be a system fix ? Since it was all good before the June update!
  14. Caomhin
    All users here, and currently backing up the phone data, and doing a full reset, then optimising the phone, is about the best way to get around heat issues.
    If you don't want to do that then Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    ItsRavi25 likes this.
  15. E1583928606175
    Donut Jun 30, 2020
  16. Artemus.
    Nougat Jun 30, 2020
    drl431, Caomhin and E1583928606175 like this.
  17. E1583928606175
    Donut Jun 30, 2020
    E1583928606175 , via OnePlus 6T , Jun 30, 2020 :
    Artemus.
    Which one did you download?​
    Incremental for OP6T as I'm on A6013 and 10.3.3
    edit: I just downloaded the full OTA and it's installing right now (25%). Hope i'll be able to reroot after that without issue.
    Edit 2 : Just boot TWRP and adb sideloaded Magisk. All is working normally.
    rhyd1am likes this.
  18. mohal
    mohal , via OnePlus 6T , Jun 30, 2020 :
    Turn off auto wallpaper changer in wallpaper. Wallpaper OnePlus photos and in screen shot below.
  19. Vikashlb
