305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. Q1540575950960
    Cupcake Jul 2, 2020
    Q1540575950960 , via OnePlus 6 , Jul 2, 2020 :
    All my apps are stating Intelligent Control
  2. ItsRavi25
    Ice Cream Sandwich Jul 2, 2020
    ItsRavi25 , via OnePlus 6T , Jul 2, 2020 :
    Change it to optimize...
    And for important app that you need notifications on priority keep it inteligent control
    drl431 and Caomhin like this.
  3. Q1540575950960
    Cupcake Jul 2, 2020
    Thank nyou will try, but this setting i never changed .. from couple of months i started feeling this issue
  4. kamzee96
    Gingerbread Jul 2, 2020
  5. Ján Hirner
  6. kamzee96
  7. Ján Hirner
    Ján Hirner , Jul 2, 2020 :
    from @Caomhin
    Reset your WiFi adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also check your router broadcast channels for interference, change them to other channels if you find a nearby router broadcasting on the same channel as yours.
    Use a WiFi analyzer to check.
    I use this one from the Playstore to check for nearby routers using the same channel as me, and I switch my channel on the router to suit.
    https://play.google.com/store/apps/details?id=com.vrem.wifianalyzer
    There is also suggested fix here by @@shravanp07, however it is quite lengthy.
    https://forums.oneplus.com/threads/...6-finally-working-i-found-a-solution.1236477/
  8. SmyLe87 , via OnePlus 6 Mirror Black , Jul 2, 2020 :
    Hello. Does anyone knows why is not showing anymore update to 10.3.4 on OnePlus 6 when checking ? I wanted to update from 9 to this and is showing that nothing is available :/.
    erzketis likes this.
  9. ItsRavi25
    I also faced this issue once
    Goto Settings>App and Notifications>See all apps>find the Bluetooth app clear cache and storage>find the Bluetooth MIDI service clear cache and storage> Reboot your device...now connect you device
    kamzee96, drl431 and Caomhin like this.
  10. ItsRavi25
    Yes ..From past few days many users facing this issue...
    I think this maybe some server issue....but you install it manually...
    Try oxygen updater..for easily installing the latest version..
  11. erzketis
    Cupcake Jul 2, 2020
    erzketis , Jul 2, 2020 :
    I have the same. I am on 10.3.3 and when I check for updates it says "up-to-date". I did have 10.3.4 pending for some time but did not have time to install it. Now it seems it's been removed. Don't do this, OnePlus!
  12. ItsRavi25
    You can still update easily..
    Download this app...the guide is given...
    https://play.google.com/store/apps/details?id=com.arjanvlek.oxygenupdater
    It will download the latest version...and install it manually....😇😇
    Artemus., drl431 and Caomhin like this.
  13. erzketis
    Cupcake Jul 2, 2020
  14. kenzel2019
    Cupcake Jul 2, 2020
    kenzel2019 , Jul 2, 2020 :
    I got T-Mobile version and converted to international variant pls help back the auto update settings
  15. kenzel2019
    Cupcake Jul 2, 2020
  16. ErHarpalSingh
    Eclair Jul 2, 2020
  17. ItsRavi25
    Caomhin likes this.
  18. nabhan.moideen
    Eclair Jul 2, 2020
    nabhan.moideen , Jul 2, 2020 :
    While calling a service number such as Vodafone Customer Care in India (199) I'm facing the below shown error. I'm guessing this has something to do with the assisted dialling feature in the Phone App. However, it still persists after disabling the same.
    Can someone confirm if this is faced by other users as well and if there's a possible fix?
  19. Caomhin
    Lollipop Jul 2, 2020
    Caomhin , via OnePlus 6T , Jul 2, 2020 :
    Seems to be a Vodafone issue.
    https://forum.vodafone.co.uk/t5/Pay-monthly/Invalid-number/td-p/2594491
  20. Caomhin
    drl431 likes this.
