305
OxygenOS 10.3.4 for the OnePlus 6 and 6T
  1. nabhan.moideen
    Eclair Jul 2, 2020
  2. nabhan.moideen
    Eclair Jul 2, 2020
    nabhan.moideen , Jul 2, 2020 :
    I regret for this. should've done few more tricks to check this. tried with various phones on the vodafone network. same error. let me check further on this.
    thanks
    Caomhin likes this.
  3. Caomhin
    Lollipop Jul 2, 2020
    Caomhin , via OnePlus 6T , Jul 2, 2020 :
    Check if Vodafone are having Network issues. They often do.
  4. nabhan.moideen
    Eclair Jul 2, 2020
    yupp called them up on a different number that i picked up from their website. They said it is temporarily disabled.
    Caomhin likes this.
  5. Caomhin
    Glad you got sorted.
    nabhan.moideen likes this.
  6. MCunha
    Gingerbread Jul 2, 2020
    MCunha , Jul 2, 2020 :
    Thanks. I gave a try, but didn't change anything.
    Still not roaming between access points.
    When changing from one ap to another it disconnects, switching to 4g before connect to the closest ap.
    Very annoying.
  7. Caomhin
    When you say find a OnePlus 6 phone, do you mean you want to purchase one?
    ItsRavi25 and rhyd1am like this.
  8. rhyd1am
    Jelly Bean Jul 2, 2020
    rhyd1am , via OnePlus Community App , Jul 2, 2020 :
    Вы имеете в виду, где вы можете купить OnePlus? Также вы должны использовать английский в соответствии с правилами форума.
  9. ItsRavi25
    Ice Cream Sandwich Jul 2, 2020
    ItsRavi25 , via OnePlus 6T , Jul 2, 2020 :
    Если в вашем телефоне включена функция включения моего устройства. Затем перейдите на этот сайт. Введите адрес электронной почты. Вы найдете свое устройство.
    https://myaccount.google.com/intro/find-your-phone
  10. ItsRavi25
    Так что будет сложно найти, если все будет удалено. Попробуйте связаться с шерифом или полицейским участком поблизости от вас.
  11. kjjm
    Froyo Jul 2, 2020
    kjjm , Jul 2, 2020 :
    You can't. I use Oxygen Updater from the play store, which alerts me to new updates and downloads them. But local upgrade is apparently necessary with converted T-mo 6Ts and stable OOS updates.
    Caomhin likes this.
  12. Caomhin
    Lollipop Jul 3, 2020
    ItsRavi25, drl431 and ironass like this.
  13. Satish_kumar_1
    Cupcake Jul 3, 2020
  14. drl431
    Marshmallow Jul 3, 2020
  15. Satish_kumar_1
    Cupcake Jul 3, 2020
    drl431 likes this.
  16. anup1111
    Cupcake Jul 3, 2020
    anup1111 , via OnePlus 6T , Jul 3, 2020 :
    I have OP6T_O2_BETA_35 .But still not getting oxygenOs 10.3.4 when I'm trying to update from third party app its says that u can lost ur all data .then what to do
